Ana içeriğe geç
Nikon Coolpix P100 Back Buttons Replacement
Neye ihtiyacın var
  1. Nikon Coolpix P100 Back Buttons Replacement, Back Buttons: adım 1, 1 resimden 1.
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100 Back Buttons Replacement: adım 2, 3 resimden 1. Nikon Coolpix P100 Back Buttons Replacement: adım 2, 3 resimden 2. Nikon Coolpix P100 Back Buttons Replacement: adım 2, 3 resimden 3.
    • On the left side of the camera, remove two screws using a Phillips #00 screwdriver.
  3. Nikon Coolpix P100 Back Buttons Replacement: adım 3, 1 resimden 1.
    • On the right side of the camera, remove the first visible screw.
  4. Nikon Coolpix P100 Back Buttons Replacement: adım 4, 1 resimden 1.
    • Lift the HDMI and A/V OUT cover to access the hidden screw.
  5. Nikon Coolpix P100 Back Buttons Replacement: adım 5, 1 resimden 1.
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100 Back Buttons Replacement: adım 6, 2 resimden 1. Nikon Coolpix P100 Back Buttons Replacement: adım 6, 2 resimden 2.
    • Remove the two screws hidden underneath the display panel.
  7. Nikon Coolpix P100 Back Buttons Replacement: adım 7, 3 resimden 1. Nikon Coolpix P100 Back Buttons Replacement: adım 7, 3 resimden 2. Nikon Coolpix P100 Back Buttons Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to gently loosen up the sides of the camera.
  8. Nikon Coolpix P100 Back Buttons Replacement: adım 8, 2 resimden 1. Nikon Coolpix P100 Back Buttons Replacement: adım 8, 2 resimden 2.
    • Carefully open the camera.
    • There are two ribbon cables when opening the camera. Make sure to properly detach them before proceeding.
  9. Nikon Coolpix P100 Back Buttons Replacement: adım 9, 2 resimden 1. Nikon Coolpix P100 Back Buttons Replacement: adım 9, 2 resimden 2.
    • This is the cover that houses the back buttons of the camera. Turn it around.
  10. Nikon Coolpix P100 Back Buttons Replacement: adım 10, 1 resimden 1.
    • Remove the six indicated screws.
  11. Nikon Coolpix P100 Back Buttons Replacement: adım 11, 2 resimden 1. Nikon Coolpix P100 Back Buttons Replacement: adım 11, 2 resimden 2.
    • Use a plastic opening tool to lift the metal plate and set it aside.
  12. Nikon Coolpix P100 Back Buttons Replacement: adım 12, 3 resimden 1. Nikon Coolpix P100 Back Buttons Replacement: adım 12, 3 resimden 2. Nikon Coolpix P100 Back Buttons Replacement: adım 12, 3 resimden 3.
    • Turn the cover around and push against the buttons.
  13. Nikon Coolpix P100 Back Buttons Replacement: adım 13, 1 resimden 1.
    • Now you have partial access to one set of buttons.
  14. Nikon Coolpix P100 Back Buttons Replacement: adım 14, 1 resimden 1.
    • Find the last set of removal buttons on the bottom left.
  15. Nikon Coolpix P100 Back Buttons Replacement: adım 15, 1 resimden 1.
    • Remove the screw.
  16. Nikon Coolpix P100 Back Buttons Replacement: adım 16, 2 resimden 1. Nikon Coolpix P100 Back Buttons Replacement: adım 16, 2 resimden 2.
    • Use a plastic opening tool to remove the button.
Sonuç
Nghiem Ngo
339 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Tanski Winter 2015 USF Tampa, Team 1-1, Tanski Winter 2015 üyesi
USFT-TANSKI-W15S1G1
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 1,058
