1. Nikon Coolpix P100. Nikon Coolpix P100.
    • Nikon Coolpix P100.
  2. Set the camera upside down so that the side with the serial number is face up. Pull back the display panel.Orient the panel so that you are able to view the back of it. Pull back the display panel.Orient the panel so that you are able to view the back of it.
    • Set the camera upside down so that the side with the serial number is face up.
    • Pull back the display panel.Orient the panel so that you are able to view the back of it.
  3. Using a Phillips head screwdriver unscrew the two screws closest to the piece connecting the panel to the camera. Using a Phillips head screwdriver unscrew the two screws closest to the piece connecting the panel to the camera.
    • Using a Phillips head screwdriver unscrew the two screws closest to the piece connecting the panel to the camera.
  4. Remove the cover that was unscrewed in the last step.
    • Remove the cover that was unscrewed in the last step.
  5. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  6. Using a Phillips head screwdriver  remove the remaining four screws on the outermost corners of the panel.
    • Using a Phillips head screwdriver remove the remaining four screws on the outermost corners of the panel.
  7. Use a plastic opening tool to pry open the back panel display screen. Use a plastic opening tool to pry open the back panel display screen. Use a plastic opening tool to pry open the back panel display screen.
    • Use a plastic opening tool to pry open the back panel display screen.
  8. Carefully unhook the ribbon that attaches the panel to the camera. Remove the top black cover of the panel. Disassembling Nikon Coolpix P100 Ribbon Cable Carefully unhook the ribbon that attaches the panel to the camera. Remove the top black cover of the panel. Disassembling Nikon Coolpix P100 Ribbon Cable Carefully unhook the ribbon that attaches the panel to the camera. Remove the top black cover of the panel. Disassembling Nikon Coolpix P100 Ribbon Cable
  9. Remove the two screws on the panel that are closest to the ribbon cable.
    • Remove the two screws on the panel that are closest to the ribbon cable.
  10. Remove the other two screws on the opposite side of the panel.
    • Remove the other two screws on the opposite side of the panel.
  11. Separate the metal portion of the screen from the plastic portion. Separate the metal portion of the screen from the plastic portion.
    • Separate the metal portion of the screen from the plastic portion.
  12. Carefully remove the ribbon connector cable from the metal portion of the display.
    • Carefully remove the ribbon connector cable from the metal portion of the display.
  13. Now you have successfully removed the display panel.
    • Now you have successfully removed the display panel.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Rikki Brown
243 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team 1-1, Tanski Winter 2015 USF Tampa, Team 1-1, Tanski Winter 2015 üyesi
USFT-TANSKI-W15S1G1
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 Gün: 7
Son 30 Gün: 30
Her zaman: 1,306
