Ana içeriğe geç
Nikon Coolpix P100 Display Screen Replacement
Neye ihtiyacın var
  1. Nikon Coolpix P100 Display Screen Replacement, Display Screen: adım 1, 3 resimden 1. Nikon Coolpix P100 Display Screen Replacement, Display Screen: adım 1, 3 resimden 2. Nikon Coolpix P100 Display Screen Replacement, Display Screen: adım 1, 3 resimden 3.
    • Flip the camera upside down so that the side with the serial number is face up.
    • Pull back the display panel. Orient the panel so that you are able to view the back of it.
  2. Nikon Coolpix P100 Display Screen Replacement: adım 2, 2 resimden 1. Nikon Coolpix P100 Display Screen Replacement: adım 2, 2 resimden 2.
    • Remove the two screws closest to the piece connecting the panel to the camera with a Phillips #1 screwdriver.
  3. Nikon Coolpix P100 Display Screen Replacement: adım 3, 1 resimden 1.
    • Remove the cover that was unscrewed in the last step.
  4. Nikon Coolpix P100 Display Screen Replacement: adım 4, 1 resimden 1.
    • Remove the remaining four screws on the outermost corners of the panel using a Phillips #1 screwdriver.
  5. Nikon Coolpix P100 Display Screen Replacement: adım 5, 3 resimden 1. Nikon Coolpix P100 Display Screen Replacement: adım 5, 3 resimden 2. Nikon Coolpix P100 Display Screen Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to pry open the back panel of the display screen.
  6. Nikon Coolpix P100 Display Screen Replacement: adım 6, 3 resimden 1. Nikon Coolpix P100 Display Screen Replacement: adım 6, 3 resimden 2. Nikon Coolpix P100 Display Screen Replacement: adım 6, 3 resimden 3.
    • Carefully unhook the ribbon that attaches the panel to the camera.
    • Remove the top black panel cover.
  7. Nikon Coolpix P100 Display Screen Replacement: adım 7, 1 resimden 1.
    • Remove the two screws on the panel that are closest to the ribbon cable using a Phillips #1 screwdriver.
  8. Nikon Coolpix P100 Display Screen Replacement: adım 8, 1 resimden 1.
    • Remove the other two screws on the opposite side of the panel using a Phillips #1 screwdriver.
  9. Nikon Coolpix P100 Display Screen Replacement: adım 9, 2 resimden 1. Nikon Coolpix P100 Display Screen Replacement: adım 9, 2 resimden 2.
    • Separate the metal portion of the screen from the plastic portion.
  10. Nikon Coolpix P100 Display Screen Replacement: adım 10, 2 resimden 1. Nikon Coolpix P100 Display Screen Replacement: adım 10, 2 resimden 2.
    • Carefully remove the ribbon connector cable from the metal portion of the display.
    • Remove the display from the rest of the device.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Rikki Brown
267 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Tanski Winter 2015 USF Tampa, Team 1-1, Tanski Winter 2015 üyesi
USFT-TANSKI-W15S1G1
3 Üyeler
8 adet Kılavuz yazıldı
3Kılavuz Yorumları
This guide help me to change my screen on Nikon P100 with out to much trouble, however I found step 7 unnecessary.
David Fyock - Yanıt
Hello, I've a problem during the re-mount of the display. Someone can help me? Thanks in advance! Mark
cwmark56 - Yanıt
I can't reconnect the connector on the step 10. Can you help me?
cwmark56 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 3,093
