Ana içeriğe geç
Nikon Coolpix P100 Viewfinder Replacement
Neye ihtiyacın var
  1. Nikon Coolpix P100 Viewfinder Replacement, Nikon Coolpix P100  Motherboard Access: adım 1, 1 resimden 1.
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100 Viewfinder Replacement: adım 2, 3 resimden 1. Nikon Coolpix P100 Viewfinder Replacement: adım 2, 3 resimden 2. Nikon Coolpix P100 Viewfinder Replacement: adım 2, 3 resimden 3.
    • On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two marked screws.
  3. Nikon Coolpix P100 Viewfinder Replacement: adım 3, 1 resimden 1.
    • On the right side of the camera, remove the first visible screw above the HDMI and A/V OUT cover.
  4. Nikon Coolpix P100 Viewfinder Replacement: adım 4, 1 resimden 1.
    • Lift the HDMI and A/V OUT cover to access the hidden screw between the two ports.
    • Remove the screw
  5. Nikon Coolpix P100 Viewfinder Replacement: adım 5, 1 resimden 1.
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100 Viewfinder Replacement: adım 6, 2 resimden 1. Nikon Coolpix P100 Viewfinder Replacement: adım 6, 2 resimden 2.
    • Turn the back of the camera toward you.
    • Lift the display panel and remove the two marked screws
  7. Nikon Coolpix P100 Viewfinder Replacement: adım 7, 3 resimden 1. Nikon Coolpix P100 Viewfinder Replacement: adım 7, 3 resimden 2. Nikon Coolpix P100 Viewfinder Replacement: adım 7, 3 resimden 3.
    • Use a plastic iFixit opening tool to gently loosen the top and sides of the camera.
  8. Nikon Coolpix P100 Viewfinder Replacement: adım 8, 1 resimden 1.
    • Before fully opening the camera, identify the two marked ribbon cables
    • Properly detach the ribbons before proceeding
  9. Nikon Coolpix P100 Viewfinder Replacement: adım 9, 1 resimden 1.
    • Carefully open the camera.
    • Now you have partial access to the camera's motherboard.
  10. Nikon Coolpix P100 Viewfinder Replacement: adım 10, 1 resimden 1.
    • Remove the five indicated screws that are attached to the metal plate.
  11. Nikon Coolpix P100 Viewfinder Replacement: adım 11, 1 resimden 1.
    • Remove the hidden top screw that is attached to the metal plate.
  12. Nikon Coolpix P100 Viewfinder Replacement: adım 12, 1 resimden 1.
    • Use a plastic iFixit opening tool to carefully loosen the metal plate.
    • Remove the metal plate to access the camera's motherboard.
  13. Nikon Coolpix P100 Viewfinder Replacement: adım 13, 1 resimden 1.
    • Now you have access to the camera's motherboard
  14. Nikon Coolpix P100 Viewfinder Replacement, Viewfinder: adım 14, 1 resimden 1.
    • Remove the screw that is located on the left of the view finder.
  15. Nikon Coolpix P100 Viewfinder Replacement: adım 15, 1 resimden 1.
    • Carefully detach the two ribbon cables and detach the viewfinder.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nghiem Ngo
330 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Tanski Winter 2015 USF Tampa, Team 1-1, Tanski Winter 2015 üyesi
USFT-TANSKI-W15S1G1
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 1,169
