Ana içeriğe geç
Nikon Coolpix P510 Battery Removal Replacement
Neye ihtiyacın var
  1. Nikon Coolpix P510 Battery Removal Replacement, Battery Removal: adım 1, 1 resimden 1.
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 Battery Removal Replacement: adım 2, 2 resimden 1. Nikon Coolpix P510 Battery Removal Replacement: adım 2, 2 resimden 2.
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
Sonuç
Brian Hulsey
1.461 İtibar
6 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-2, Panko Spring 2015 Colorado Springs, Team 2-2, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G2
3 Üyeler
12 adet Kılavuz yazıldı
3 Yorum
Even a 3 grader can figure this out. My problem is that I do this and the battery doesn't come up. It's stuck. What should I do???
victoria - Yanıt
Victoria, has had that problem too. In my case the battery was bloated. I had to wiggle it out with a butter knife until I could get a grip on it. I had to replace the battery.
david murray - Yanıt
Thank you so much for this information. I used a metal nail file and small pliers. It worked and the battery was swollen
klrider1961 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 28
Her zaman: 4,077
