Ana içeriğe geç
Nikon Coolpix P510 LCD Replacement
Neye ihtiyacın var
  1. Nikon Coolpix P510 LCD Replacement, Battery Removal: adım 1, 1 resimden 1.
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 LCD Replacement: adım 2, 2 resimden 1. Nikon Coolpix P510 LCD Replacement: adım 2, 2 resimden 2.
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
  3. Nikon Coolpix P510 LCD Replacement, LCD Screen Window: adım 3, 2 resimden 1. Nikon Coolpix P510 LCD Replacement, LCD Screen Window: adım 3, 2 resimden 2.
    • Extend the LCD screen out and turn the camera upside down to get access to the screws on the bottom.
  4. Nikon Coolpix P510 LCD Replacement: adım 4, 2 resimden 1. Nikon Coolpix P510 LCD Replacement: adım 4, 2 resimden 2.
    • Take the four 4mm PH00 Phillips screws out.
  5. Nikon Coolpix P510 LCD Replacement: adım 5, 2 resimden 1. Nikon Coolpix P510 LCD Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to trace around the screen to pop the front and back section apart.
  6. Nikon Coolpix P510 LCD Replacement, LCD: adım 6, 2 resimden 1. Nikon Coolpix P510 LCD Replacement, LCD: adım 6, 2 resimden 2.
    • Tilt the LCD up to get access to the back of it.
  7. Nikon Coolpix P510 LCD Replacement: adım 7, 2 resimden 1. Nikon Coolpix P510 LCD Replacement: adım 7, 2 resimden 2.
    • Unplug the ribbon cables on the side of the chip under the LCD by simple pulling lightly on them.
  8. Nikon Coolpix P510 LCD Replacement: adım 8, 1 resimden 1.
    • The chip has an adhesive on it to keep it attached to the LCD, and you will need to use a plastic opening tool to get it off.
    • It may take a little bit of pressure to get the chip off. Be gentle to make sure you don't break the chip.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Brian Hulsey
1.506 İtibar
6 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-2, Panko Spring 2015 Colorado Springs, Team 2-2, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G2
3 Üyeler
12 adet Kılavuz yazıldı
2Kılavuz Yorumları
Esse LSD tem outro fita preta que conecta pode estar ruim
Leonardo Silva - Yanıt
Porque a minha não sei se ela é LCD ou esse negócio preto que conecta que tá ruim
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 43
Her zaman: 6,047
