Ana içeriğe geç
Nikon Coolpix P510 Lens Assembly Replacement
Neye ihtiyacın var
    1. Nikon Coolpix P510 Lens Assembly Replacement, Lens Assembly: adım 1, 2 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement, Lens Assembly: adım 1, 2 resimden 2.
      • Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
      • On the thumb grip, remove the one 4mm PH00 Philips screw.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix P510 Lens Assembly Replacement: adım 2, 1 resimden 1.
      • With the camera upside down, remove the three 3mm PH00 Philips screws on the left side.
      • One of the screws are under the HDMI and A/V Out cover.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix P510 Lens Assembly Replacement: adım 3, 1 resimden 1.
      • On the opposite side of the camera, remove the two 3mm PH00 Philips screws.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon Coolpix P510 Lens Assembly Replacement: adım 4, 1 resimden 1.
      • open the display and remove the two Ph 00 screws near the hinge
      FixBot'a Sor
      Yorum Ekle
    5. Nikon Coolpix P510 Lens Assembly Replacement: adım 5, 3 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 5, 3 resimden 2. Nikon Coolpix P510 Lens Assembly Replacement: adım 5, 3 resimden 3.
      • Open the flash and use a plastic opening tool to pop the tab under it as shown.
      • Now pull the casing apart.
      • The tripod attachment may fall out on its own, or you will need to pull it out.
      FixBot'a Sor
      Yorum Ekle
    6. Nikon Coolpix P510 Lens Assembly Replacement: adım 6, 2 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 6, 2 resimden 2.
      • Unplug the two ribbon cables to completely detach the back, by securely opening the latch
      FixBot'a Sor
      Yorum Ekle
    7. Nikon Coolpix P510 Lens Assembly Replacement: adım 7, 3 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 7, 3 resimden 2. Nikon Coolpix P510 Lens Assembly Replacement: adım 7, 3 resimden 3.
      • With the back separated, you need to remove six 3mm PH000 Philips screws with a Philips screwdriver.
      • Remove one 5mm PH00 Philips screw
      • To remove the top right corner screw, you may need to lift the corner of the case to gain access to it.
      • With all the screws out, the metal plate should simply lift off.
      FixBot'a Sor
      Yorum Ekle
    8. Nikon Coolpix P510 Lens Assembly Replacement: adım 8, 2 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 8, 2 resimden 2.
      • With the metal plate off, unplug this ribbon cable from the motherboard.
      • To remove the flat-topped connector, you simply lift it up to unplug it.
      FixBot'a Sor
      Yorum Ekle
    9. Nikon Coolpix P510 Lens Assembly Replacement: adım 9, 3 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 9, 3 resimden 2. Nikon Coolpix P510 Lens Assembly Replacement: adım 9, 3 resimden 3.
      • To get the lens assembly out, you need to remove four 6mm PH00 Philips screws
      FixBot'a Sor
      Yorum Ekle
    10. Nikon Coolpix P510 Lens Assembly Replacement: adım 10, 2 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 10, 2 resimden 2.
      • With the support screws out, you can simply slide the assembly out of the casing.
      FixBot'a Sor
      Yorum Ekle
    11. Nikon Coolpix P510 Lens Assembly Replacement: adım 11, 3 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 11, 3 resimden 2. Nikon Coolpix P510 Lens Assembly Replacement: adım 11, 3 resimden 3.
      • If you are moving on to take the lens casing off, you do not need to do this step.
      • With the assembly out we need to take of this last piece by removing the three 3mm PH000 Philips screws.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Brian Hulsey
1.554 İtibar
6 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-2, Panko Spring 2015 Colorado Springs, Team 2-2, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G2
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 70
Her zaman: 4,897
