Ana içeriğe geç
Nikon Coolpix P510 Lens Assembly Replacement
Neye ihtiyacın var
  1. Nikon Coolpix P510 Lens Assembly Replacement, Lens Assembly: adım 1, 2 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement, Lens Assembly: adım 1, 2 resimden 2.
    • Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
    • On the thumb grip, remove the one 4mm PH00 Philips screw.
  2. Nikon Coolpix P510 Lens Assembly Replacement: adım 2, 1 resimden 1.
    • With the camera upside down, remove the three 3mm PH00 Philips screws on the left side.
    • One of the screws are under the HDMI and A/V Out cover.
  3. Nikon Coolpix P510 Lens Assembly Replacement: adım 3, 1 resimden 1.
    • On the opposite side of the camera, remove the two 3mm PH00 Philips screws.
  4. Nikon Coolpix P510 Lens Assembly Replacement: adım 4, 3 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 4, 3 resimden 2. Nikon Coolpix P510 Lens Assembly Replacement: adım 4, 3 resimden 3.
    • Open the flash and use a plastic opening tool to pop the tab under it as shown.
    • Now pull the casing apart.
    • The tripod attachment may fall out on its own, or you will need to pull it out.
  5. Nikon Coolpix P510 Lens Assembly Replacement: adım 5, 2 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 5, 2 resimden 2.
    • Unplug the two ribbon cables to completely detach the back.
  6. Nikon Coolpix P510 Lens Assembly Replacement: adım 6, 3 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 6, 3 resimden 2. Nikon Coolpix P510 Lens Assembly Replacement: adım 6, 3 resimden 3.
    • With the back separated, you need to remove six 3mm PH000 Philips screws with a Philips screwdriver.
    • Remove one 5mm PH00 Philips screw
    • To remove the top right corner screw, you may need to lift the corner of the case to gain access to it.
    • With all the screws out, the metal plate should simply lift off.
  7. Nikon Coolpix P510 Lens Assembly Replacement: adım 7, 2 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 7, 2 resimden 2.
    • With the metal plate off, unplug this ribbon cable from the motherboard.
    • To remove the flat-topped connector, you simply lift it up to unplug it.
  8. Nikon Coolpix P510 Lens Assembly Replacement: adım 8, 3 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 8, 3 resimden 2. Nikon Coolpix P510 Lens Assembly Replacement: adım 8, 3 resimden 3.
    • To get the lens assembly out, you need to remove four 6mm PH00 Philips screws
  9. Nikon Coolpix P510 Lens Assembly Replacement: adım 9, 2 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 9, 2 resimden 2.
    • With the support screws out, you can simply slide the assembly out of the casing.
  10. Nikon Coolpix P510 Lens Assembly Replacement: adım 10, 3 resimden 1. Nikon Coolpix P510 Lens Assembly Replacement: adım 10, 3 resimden 2. Nikon Coolpix P510 Lens Assembly Replacement: adım 10, 3 resimden 3.
    • If you are moving on to take the lens casing off, you do not need to do this step.
    • With the assembly out we need to take of this last piece by removing the three 3mm PH000 Philips screws.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Brian Hulsey
1.461 İtibar
6 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-2, Panko Spring 2015 Colorado Springs, Team 2-2, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G2
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 3,600
