Ana içeriğe geç
Nikon Coolpix P530 Battery Replacement
Neye ihtiyacın var
  1. Nikon Coolpix P530 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Identify the battery chamber found at the bottom of the device.
    • Ensure the camera is turned off before conducting any maintenance on the device.
  2. Nikon Coolpix P530 Battery Replacement: adım 2, 3 resimden 1. Nikon Coolpix P530 Battery Replacement: adım 2, 3 resimden 2. Nikon Coolpix P530 Battery Replacement: adım 2, 3 resimden 3.
    • Slide the switch to the left to open the battery chamber using your fingertip or plastic opening tools.
    • The spring loaded battery chamber door will swing open after the switch is moved.
  3. Nikon Coolpix P530 Battery Replacement: adım 3, 3 resimden 1. Nikon Coolpix P530 Battery Replacement: adım 3, 3 resimden 2. Nikon Coolpix P530 Battery Replacement: adım 3, 3 resimden 3.
    • Depress the yellow spring loaded tab holding the battery in place using your fingertip or plastic opening tools.
    • After the yellow tab is depressed, the battery should partially eject from the camera.
  4. Nikon Coolpix P530 Battery Replacement: adım 4, 2 resimden 1. Nikon Coolpix P530 Battery Replacement: adım 4, 2 resimden 2.
    • Gently remove the battery from the chamber.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Thanks. Just checking the camera issues.
Suzanne von Leuschner - Yanıt
I can’t get the battery out of my camera. I've had the camera for 5 years with no previous problems. Any suggestions?
Bonnie Laub - Yanıt
top of the battery gets very hot when inserted .Is this normal?
Lowell Schiller - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 29
Her zaman: 3,666
