Ana içeriğe geç
Nikon Coolpix P90 LCD Screen Replacement
Neye ihtiyacın var
  1. Nikon Coolpix P90 LCD Screen Replacement, Camera Base: adım 1, 3 resimden 1. Nikon Coolpix P90 LCD Screen Replacement, Camera Base: adım 1, 3 resimden 2. Nikon Coolpix P90 LCD Screen Replacement, Camera Base: adım 1, 3 resimden 3.
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
  2. Nikon Coolpix P90 LCD Screen Replacement, LCD Screen: adım 2, 3 resimden 1. Nikon Coolpix P90 LCD Screen Replacement, LCD Screen: adım 2, 3 resimden 2. Nikon Coolpix P90 LCD Screen Replacement, LCD Screen: adım 2, 3 resimden 3.
    • Use a Phillips #000 Precision Screwdriver for all of the following steps.
    • Remove both 4.5 mm screws holding the bottom into place.
    • Remove both 4.5 mm screws holding the side into place.
    • Remove the 4.5 mm screw underneath the A/V flap.
    • Remove the 4.0 mm screw on the left-side wrist strap loop.
  3. Nikon Coolpix P90 LCD Screen Replacement: adım 3, 2 resimden 1. Nikon Coolpix P90 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Lift up the LCD screen to reveal the two screws.
    • Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws that hold the arm in place.
    Before I could remove the back from my camera, I also had to remove a small screw under the pop-up flash head, near the left hinge looking at the camera from the front.
    Dennis - Yanıt
  4. Nikon Coolpix P90 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Carefully lift the back cover from the camera.
    • Do NOT completely remove the back cover from the camera yet. There is a data transfer ribbon connecting the LCD screen to the motherboard.
  5. Nikon Coolpix P90 LCD Screen Replacement: adım 5, 2 resimden 1. Nikon Coolpix P90 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Press your finger on the top of the latch and pull it down and towards you to open the safety latch and free the ribbon.
    • Be careful when removing the safety latch as it is fragile and may break easily.
    • Slide the ribbon out from its socket.
    • It is now safe to completely remove the back cover from the camera.
  6. Nikon Coolpix P90 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Using a Phillips #000 Precision Screwdriver, remove the two 6.0 mm screws from the inner back panel that hold the LCD screen arm in place.
  7. Nikon Coolpix P90 LCD Screen Replacement: adım 7, 3 resimden 1. Nikon Coolpix P90 LCD Screen Replacement: adım 7, 3 resimden 2. Nikon Coolpix P90 LCD Screen Replacement: adım 7, 3 resimden 3.
    • Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws.
    • Remove the plastic cover from the LCD screen arm.
  8. Nikon Coolpix P90 LCD Screen Replacement: adım 8, 3 resimden 1. Nikon Coolpix P90 LCD Screen Replacement: adım 8, 3 resimden 2. Nikon Coolpix P90 LCD Screen Replacement: adım 8, 3 resimden 3.
    • Lift and rotate the plastic connector counter-clockwise, clockwise, then counter-clockwise again.
    • Remove the plastic connector from the LCD screen arm.
  9. Nikon Coolpix P90 LCD Screen Replacement: adım 9, 2 resimden 1. Nikon Coolpix P90 LCD Screen Replacement: adım 9, 2 resimden 2.
    • Using a Phillips #000 Precision Screwdriver, remove the two 4.0 mm screws.
    • Take off the plastic covering to reveal the inner components of the LCD screen.
  10. Nikon Coolpix P90 LCD Screen Replacement: adım 10, 2 resimden 1. Nikon Coolpix P90 LCD Screen Replacement: adım 10, 2 resimden 2.
    • Using a Phillips #000 Precision Screwdriver, remove the four 3.0 mm screws.
    • Using your fingers, remove the two plastic borders that case the LCD screen.
    • A plastic opening tool is not necessary, but may be helpful.
  11. Nikon Coolpix P90 LCD Screen Replacement: adım 11, 2 resimden 1. Nikon Coolpix P90 LCD Screen Replacement: adım 11, 2 resimden 2.
    • Using a Phillips #000 Precision Screwdriver, remove both 3.5 mm screws from either side of the LCD screen.
    • Remove the LCD screen from the screen cover.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Elizabeth Kamine
655 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-14, Maness Winter 2015 Cal Poly, Team 20-14, Maness Winter 2015 üyesi
CPSU-MANESS-W15S20G14
4 Üyeler
7 adet Kılavuz yazıldı
4 Yorum
Hello Elizabeth,
I have just followed the video’s for replacing a screen on my Coolpix P90.
The procedure was excellent and for an old Australian (born 1931) I never had a problem.
Just one question, is there a special way for reconnecting the data transfer ribbon.
Just cannot reconnect.
Thank you.
Regards, Noman
QLD Australia.
normanlaundry - Yanıt
Hello,
Where can I buy a screen for replacement?
Thanks - Paul
Paul - Yanıt
Help! I must be missing something. I only need to replace the screen and I can’t get the angled screen to lay flat. Because of this I cant access the two screws on the back “extension” piece allowing me to remove the plastic cover on the back of the screen. The camera is a coolpix P90. Any advice?
Alexis - Yanıt
I also need to know where to buy a new screen.
Everywhere I look on line there are only parts listed for newer models.
Thanks, Allen
Soothing Sounds - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 2,390
