Giriş
This is the first part to taking apart your Nikon Coolpix S210.
Parçalar
Hiçbir parçaya gerek yok.
  1. Place thumb on the battery cover panel on the bottom of the device.
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Slide the orange latch outward towards the corner of the camera. The battery should pop out.
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  5. Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  6. Unscrew the two 4.05mm screws on the side next to the buttons.
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  7. Gently wedge the flat end of the spudger between the back case and the wrist-strap mount. The wrist-strap mount is the thin metal piece on the side of the camera.  Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
Sonuç
To reassemble your device, follow these instructions in reverse order, paying careful attention to the locations of the different sizes of screws.
Bir başkası bu kılavuzu tamamladı.
Paul Doyle
470 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-17, Amido Winter 2011 Cal Poly, Team 5-17, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S5G17
6 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
What about the front case so I can replace the flash board on top?
danwat1234 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 6
Her zaman: 1,999
