Ana içeriğe geç
Nikon Coolpix S220 Battery and Memory Card Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S220 Battery and Memory Card Replacement, Battery and Memory Card: adım 1, 1 resimden 1.
    • Slide the battery and memory card cover (located on the bottom of the camera) to release it.
  2. Nikon Coolpix S220 Battery and Memory Card Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • To release battery you must slide the orange hatch, once doing so the battery will pop up.
    • Remove with tweezers or your fingers.
  3. Nikon Coolpix S220 Battery and Memory Card Replacement: adım 3, 1 resimden 1.
    • To release the memory card, simply push down on the memory card and it will pop up as the battery did.
    • You will be able to remove with your fingers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Shauna
798 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-32, Maness Spring 2011 Cal Poly, Team 12-32, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G32
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
bonitakale - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 67
Her zaman: 19,636
