Giriş
Your Nikon Coolpix S30 camera is powered by two AA batteries. If your camera won't turn on, its batteries may be out of power. Follow this guide to remove the old batteries and install new ones. This may solve the problem and avoid other more complicated repairs. This guide will explain how to remove the battery compartment cover, change the batteries, and replace the cover securely.
Before starting this process, disconnect the camera from its charger.
Neye ihtiyacın var
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Cover not sliding open. Is there a way to loosen and adjust. Need to put in new batteries.
i am having same problem
