Ana içeriğe geç
Nikon Coolpix S3100 Camera Disassembly
Neye ihtiyacın var
  1. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: adım 1, 3 resimden 1. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: adım 1, 3 resimden 2. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: adım 1, 3 resimden 3.
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Disassembly: adım 2, 2 resimden 1. Nikon Coolpix S3100 Camera Disassembly: adım 2, 2 resimden 2.
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Disassembly: adım 3, 2 resimden 1. Nikon Coolpix S3100 Camera Disassembly: adım 3, 2 resimden 2.
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 Camera Disassembly: adım 4, 2 resimden 1. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 Camera Disassembly: adım 4, 2 resimden 2.
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
    • Gently pull the orange board to the right. (picture 2)
  5. Nikon Coolpix S3100 Camera Disassembly: adım 5, 3 resimden 1. Nikon Coolpix S3100 Camera Disassembly: adım 5, 3 resimden 2. Nikon Coolpix S3100 Camera Disassembly: adım 5, 3 resimden 3.
    • Lift screen up holding the corners.
    • Gently pull to the left to release from ZIF connector. (picture 2)
    • Gently pull the orange board to the right. (picture 3)
  6. Nikon Coolpix S3100 Camera Disassembly: adım 6, 2 resimden 1. Nikon Coolpix S3100 Camera Disassembly: adım 6, 2 resimden 2.
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
    • Gently pull the shutter up. (picture 2)
  7. Nikon Coolpix S3100 Camera Disassembly: adım 7, 2 resimden 1. Nikon Coolpix S3100 Camera Disassembly: adım 7, 2 resimden 2.
    • Lens is now separated from body.
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  8. Nikon Coolpix S3100 Camera Disassembly: adım 8, 3 resimden 1. Nikon Coolpix S3100 Camera Disassembly: adım 8, 3 resimden 2. Nikon Coolpix S3100 Camera Disassembly: adım 8, 3 resimden 3.
    • Use a nylon or metal spudger to release the lens.
    • Repeat step 4 to the opposite side of the lens. (picture 2)
    • Lens is now separated from metal.
  9. Nikon Coolpix S3100 Camera Disassembly: adım 9, 3 resimden 1. Nikon Coolpix S3100 Camera Disassembly: adım 9, 3 resimden 2. Nikon Coolpix S3100 Camera Disassembly: adım 9, 3 resimden 3.
    • Once you have all the parts separated, start cleaning them with an air compressor bottle. (as shown)
    • Using the provided straw, start spraying the parts. (pictures 2 and 3)
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jorge
1.170 İtibar
7 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-4, Panko Spring 2015 Colorado Springs, Team 2-4, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G4
2 Üyeler
13 adet Kılavuz yazıldı
1Rehber Yorum
accidentally touched the wires for the cap even though i read the warning, can confirm, not fun
zettabyte - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 82
Her zaman: 3,573
