Ana içeriğe geç
Nikon Coolpix S3100 Camera LCD Screen Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S3100 Camera LCD Screen Replacement, Nikon Coolpix S3100 disassembly: adım 1, 3 resimden 1. Nikon Coolpix S3100 Camera LCD Screen Replacement, Nikon Coolpix S3100 disassembly: adım 1, 3 resimden 2. Nikon Coolpix S3100 Camera LCD Screen Replacement, Nikon Coolpix S3100 disassembly: adım 1, 3 resimden 3.
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera LCD Screen Replacement: adım 2, 2 resimden 1. Nikon Coolpix S3100 Camera LCD Screen Replacement: adım 2, 2 resimden 2.
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera LCD Screen Replacement: adım 3, 2 resimden 1. Nikon Coolpix S3100 Camera LCD Screen Replacement: adım 3, 2 resimden 2.
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera LCD Screen Replacement, LCD Screen: adım 4, 1 resimden 1.
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
  5. Nikon Coolpix S3100 Camera LCD Screen Replacement: adım 5, 1 resimden 1.
    • Gently pull the orange board to the right.
  6. Nikon Coolpix S3100 Camera LCD Screen Replacement: adım 6, 1 resimden 1.
    • Lift screen up holding both corners.
  7. Nikon Coolpix S3100 Camera LCD Screen Replacement: adım 7, 1 resimden 1.
    • Gently pull to the left to release from ZIF connector.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jorge
1.170 İtibar
7 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-4, Panko Spring 2015 Colorado Springs, Team 2-4, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G4
2 Üyeler
13 adet Kılavuz yazıldı
4Kılavuz Yorumları
No mention of getting an electric shock while removing the case.Bit of a tingle anyway.I held the camera in a plastic bag after that.
Sindento 1 - Yanıt
This will probably not be replied to, but is there any reliable way to discharge the flash capacitor? Got shocked once, but I thought it was already discharged lol.
Anirban Bhattacharyya - Yanıt
Connect a 1k ohm resister between the black and red wire from the capacitor. Give it a few moments to discharge through the resistor. Don't discharge the capacitor without a resistor as you run a good chance of destroying the electronics. Wear your latex gloves too.
gary.grant - Yanıt
Easy to follow
Janet Miles - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 55
Her zaman: 2,684
