Ana içeriğe geç
Nikon Coolpix S3100 Camera Lens Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: adım 1, 3 resimden 1. Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: adım 1, 3 resimden 2. Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: adım 1, 3 resimden 3.
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Lens Replacement: adım 2, 2 resimden 1. Nikon Coolpix S3100 Camera Lens Replacement: adım 2, 2 resimden 2.
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Lens Replacement: adım 3, 2 resimden 1. Nikon Coolpix S3100 Camera Lens Replacement: adım 3, 2 resimden 2.
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Lens Replacement, LCD Screen: adım 4, 1 resimden 1.
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
  5. Nikon Coolpix S3100 Camera Lens Replacement: adım 5, 1 resimden 1.
    • Gently pull the orange board to the right.
  6. Nikon Coolpix S3100 Camera Lens Replacement: adım 6, 1 resimden 1.
    • Lift screen up holding both corners.
  7. Nikon Coolpix S3100 Camera Lens Replacement: adım 7, 1 resimden 1.
    • Gently pull to the left to release from ZIF connector.
  8. Nikon Coolpix S3100 Camera Lens Replacement, Lens: adım 8, 1 resimden 1.
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
  9. Nikon Coolpix S3100 Camera Lens Replacement: adım 9, 1 resimden 1.
    • Gently pull the shutter up.
  10. Nikon Coolpix S3100 Camera Lens Replacement: adım 10, 1 resimden 1.
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  11. Nikon Coolpix S3100 Camera Lens Replacement: adım 11, 1 resimden 1.
    • Use a nylon or metal spudger to release the lens.
  12. Nikon Coolpix S3100 Camera Lens Replacement: adım 12, 1 resimden 1.
    • Repeat step 4 to the opposite side of the lens.
  13. Nikon Coolpix S3100 Camera Lens Replacement: adım 13, 1 resimden 1.
    • The lens is now separated.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Jorge
1.170 İtibar
7 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-4, Panko Spring 2015 Colorado Springs, Team 2-4, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G4
2 Üyeler
13 adet Kılavuz yazıldı
6 Yorum
My lens shutter does not open correctly. After turning the camera on, the shutter only half opens with a juddering motion. Any ideas?
Anita
William Dawson - Yanıt
Nikon coolpix s3100 lens mocking place help my
Nanji Buchiya - Yanıt
My lens shutter does not open correctly after turning on and after close with juddering repeatly how can be repaired
Bimolthou Thuodam - Yanıt
I have same issue it shutter half opens and doesnt open correctly
shailendra - Yanıt
my LCD screen is stuck on white after after i did this :(
andrew welles - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 45
Her zaman: 4,122
