Ana içeriğe geç
Nikon Coolpix S3500 Rear Buttons Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S3500 Rear Buttons  Replacement, Back Panel Disassembly: adım 1, 2 resimden 1. Nikon Coolpix S3500 Rear Buttons  Replacement, Back Panel Disassembly: adım 1, 2 resimden 2.
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
  2. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 2, 2 resimden 1. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 2, 2 resimden 2.
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
  3. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 3, 2 resimden 1. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 3, 2 resimden 2.
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
  4. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 4, 2 resimden 1. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 4, 2 resimden 2.
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
  5. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 5, 3 resimden 1. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 5, 3 resimden 2. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 5, 3 resimden 3.
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
  6. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 6, 2 resimden 1. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 6, 2 resimden 2.
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
  7. Nikon Coolpix S3500 Rear Buttons  Replacement, Rear Buttons: adım 7, 1 resimden 1.
    • Take the rear panel of the device in the palm of your hand with the buttons facing downward.
  8. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 8, 3 resimden 1. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 8, 3 resimden 2. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 8, 3 resimden 3.
    • On the back side of the device's rear panel, you will see the plastic brackets that hold the rear function buttons in place.
    • With your other hand, take the pry tool and start working your way around the edge of the buttons
  9. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 9, 2 resimden 1. Nikon Coolpix S3500 Rear Buttons  Replacement: adım 9, 2 resimden 2.
    • Now, take the hand that was previously holding the pry tool, and finish pulling off the rear function buttons.
Sonuç
Jordan Rosemeyer
491 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 410
