Ana içeriğe geç
Nikon Coolpix S3500 Shutter Release Button Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S3500 Shutter Release Button Replacement, Back Panel Disassembly: adım 1, 2 resimden 1. Nikon Coolpix S3500 Shutter Release Button Replacement, Back Panel Disassembly: adım 1, 2 resimden 2.
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
  2. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 2, 2 resimden 1. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 2, 2 resimden 2.
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
  3. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 3, 2 resimden 1. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 3, 2 resimden 2.
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
  4. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 4, 2 resimden 1. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 4, 2 resimden 2.
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
  5. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 5, 3 resimden 1. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 5, 3 resimden 2. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 5, 3 resimden 3.
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
  6. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 6, 2 resimden 1. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 6, 2 resimden 2.
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
  7. Nikon Coolpix S3500 Shutter Release Button Replacement, Shutter Release Button: adım 7, 1 resimden 1.
    • Place the device shutter side down onto your hand.
  8. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 8, 3 resimden 1. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 8, 3 resimden 2. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 8, 3 resimden 3.
    • Take the thumb of the hand holding the device and place it on the plastic front panel.
    • Make sure to be gentle so no damage is done to any of the inner components of the device.
    • With your free hand, grip the outer edge of the LCD screen and start to pull the LCD from the front panel of the device.
    • This should cause the two pieces to separate from each other.
  9. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 9, 2 resimden 1. Nikon Coolpix S3500 Shutter Release Button Replacement: adım 9, 2 resimden 2.
    • Now that the 2 pieces are separated, take your free hand and gently press down on the shutter release button.
    • This should cause the shutter release button to come free from the front panel of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jordan Rosemeyer
491 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 650
