Ana içeriğe geç
Nikon Coolpix S4100 Functional Button Plate Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S4100 Functional Button Plate Replacement, External Casing: adım 1, 3 resimden 1. Nikon Coolpix S4100 Functional Button Plate Replacement, External Casing: adım 1, 3 resimden 2. Nikon Coolpix S4100 Functional Button Plate Replacement, External Casing: adım 1, 3 resimden 3.
    • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
    • There are 2 on each side, and 4 on the bottom.
  2. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 2, 1 resimden 1.
    • Remove the black casing on the back of the camera that runs around the LCD screen.
  3. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 3, 1 resimden 1.
    • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
  4. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 4, 3 resimden 1. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 4, 3 resimden 2. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 4, 3 resimden 3.
    • Pry off the front shell casing.
    • If you find this difficult, use a prying tool to help gently remove the casing.
  5. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 5, 1 resimden 1.
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
  6. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 6, 2 resimden 1. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 6, 2 resimden 2.
    • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
  7. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 7, 3 resimden 1. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 7, 3 resimden 2. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 7, 3 resimden 3.
    • Remove the lanyard mount and accompanying side shell casing off of the camera.
  8. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 8, 1 resimden 1.
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
  9. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 9, 1 resimden 1.
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
  10. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 10, 1 resimden 1.
    • Remove the remaining side shell casing.
  11. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 11, 1 resimden 1.
    • Remove the top shell casing.
  12. Nikon Coolpix S4100 Functional Button Plate Replacement, Functional Button Plate: adım 12, 1 resimden 1.
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
  13. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 13, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using precision tweezers, remove the ribbon cable that runs from the functional buttons plate to the under side of the motherboard.
  14. Nikon Coolpix S4100 Functional Button Plate Replacement: adım 14, 1 resimden 1.
    • Using precision tweezers, lift up the bottom of the functional buttons plate and remove the metal plate.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew Willis
586 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-2, Williams Fall 2015 Baylor, Team 4-2, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S4G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 363
