Ana içeriğe geç
Nikon Coolpix S51c Back Cover Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S51c Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Nikon Coolpix S51c Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
  2. Nikon Coolpix S51c Back Cover Replacement: adım 2, 1 resimden 1.
    • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using the Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Back Cover Replacement: adım 3, 1 resimden 1.
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Back Cover Replacement: adım 4, 1 resimden 1.
    • Lift the back cover.
    • Be careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Back Cover Replacement: adım 5, 1 resimden 1.
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
    • Carefully remove the back cover.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan
155 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-24, Garner Spring 2011 Cal Poly, Team 18-24, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G24
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 1,361
