Ana içeriğe geç
Nikon Coolpix S51c Lens Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S51c Lens Replacement, Back Cover: adım 1, 2 resimden 1. Nikon Coolpix S51c Lens Replacement, Back Cover: adım 1, 2 resimden 2.
    • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
  2. Nikon Coolpix S51c Lens Replacement: adım 2, 1 resimden 1.
    • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using the Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Lens Replacement: adım 3, 1 resimden 1.
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Lens Replacement: adım 4, 1 resimden 1.
    • Lift the back cover.
    • Be careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Lens Replacement: adım 5, 1 resimden 1.
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
    • Carefully remove the back cover.
  6. Nikon Coolpix S51c Lens Replacement, Lens: adım 6, 3 resimden 1. Nikon Coolpix S51c Lens Replacement, Lens: adım 6, 3 resimden 2. Nikon Coolpix S51c Lens Replacement, Lens: adım 6, 3 resimden 3.
    • Remove the five screws on the metal plate.
    • One of them is in a hole in the corner of the metal plate.
    • Remove the screw at the bottom of the camera.
    • Carefully lift the metal plate from the right side to reveal a ribbon connected to the motherboard.
  7. Nikon Coolpix S51c Lens Replacement: adım 7, 2 resimden 1. Nikon Coolpix S51c Lens Replacement: adım 7, 2 resimden 2.
    • Lift the white flap with the spudger to release the ribbon.
    • Remove the back metal plate.
  8. Nikon Coolpix S51c Lens Replacement: adım 8, 3 resimden 1. Nikon Coolpix S51c Lens Replacement: adım 8, 3 resimden 2. Nikon Coolpix S51c Lens Replacement: adım 8, 3 resimden 3.
    • Lift the two ribbons with the spudger to disconnect the lens and pull it out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan
155 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-24, Garner Spring 2011 Cal Poly, Team 18-24, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G24
4 Üyeler
2Kılavuz Yorumları
question: any source for replacement lens block ? can't find any on the internet
Cyrille Dupuydauby - Yanıt
question: any source for lens block ? I can't find any on the internet
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 34
Her zaman: 1,576
