Ana içeriğe geç
Nikon Coolpix S5200 LCD Screen Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • There are four 0.1 mm screws holding the front and back of the camera together all along the outside of the camera
    • There should be four screws
  2. Nikon Coolpix S5200 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Use the Phillips Head screw driver head to remove the four 0.1 mm screws surrounding the outer edges of the camera
  3. Nikon Coolpix S5200 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Pull the plastic back cover off of and away from the LCD screen
  4. Nikon Coolpix S5200 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Carefully remove the LCD screen from the silver plate that once held it in place by pulling it away from the internal components
  5. Nikon Coolpix S5200 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Remove the six designated screws sized 0.1 mm from the metal plate using a Phillip's Head screwdriver in size PH00.
  6. Nikon Coolpix S5200 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Lift the metal plate away from the internal components of the camera
  7. Nikon Coolpix S5200 LCD Screen Replacement: adım 7, 2 resimden 1. Nikon Coolpix S5200 LCD Screen Replacement: adım 7, 2 resimden 2.
    • Carefully remove the LCD screen by pulling it away from the camera. Repeat these steps in reverse order to install the new LCD screen.
Sonuç
Andy Powers
391 İtibar
3 adet Kılavuz yazıldı
Bir Yorum
Shouldn't the replacement LCD screen be considered a part? It is in fact very difficult to replace it without having the part to replace.
joshronsen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 1,060
