Ana içeriğe geç
Nikon Coolpix S5300 Outer Casing Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S5300  Outer Casing Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the camera upside down and locate the battery compartment.
    • Slide the compartment open following the direction of the arrow.
  2. Nikon Coolpix S5300  Outer Casing Replacement: adım 2, 1 resimden 1.
    • Press the orange release button to release and remove the battery.
    • Replace or insert battery in it's respective terminals
  3. Nikon Coolpix S5300  Outer Casing Replacement, Outer Casing: adım 3, 3 resimden 1. Nikon Coolpix S5300  Outer Casing Replacement, Outer Casing: adım 3, 3 resimden 2. Nikon Coolpix S5300  Outer Casing Replacement, Outer Casing: adım 3, 3 resimden 3.
    • Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
    • Using the same screwdriver, remove the 2 screws on the side of the camera.
    • Remove the 2 screws from the other side of the camera.
    • One of the screws is under the I/O port cover.
  4. Nikon Coolpix S5300  Outer Casing Replacement: adım 4, 3 resimden 1. Nikon Coolpix S5300  Outer Casing Replacement: adım 4, 3 resimden 2. Nikon Coolpix S5300  Outer Casing Replacement: adım 4, 3 resimden 3.
    • Use the plastic opening tool to carefully separate the cover from the camera.
    • Work the plastic opening tool around all the edges of the front plate.
    • Pull the purple plastic cover off gently from the screen.
  5. Nikon Coolpix S5300  Outer Casing Replacement: adım 5, 3 resimden 1. Nikon Coolpix S5300  Outer Casing Replacement: adım 5, 3 resimden 2. Nikon Coolpix S5300  Outer Casing Replacement: adım 5, 3 resimden 3.
    • Turn the camera over so the LCD screen is facing you.
    • Carefully remove the front shell by gently prying around the corners with the plastic opening tool until it releases.
  6. Nikon Coolpix S5300  Outer Casing Replacement: adım 6, 2 resimden 1. Nikon Coolpix S5300  Outer Casing Replacement: adım 6, 2 resimden 2.
    • Be careful to keep track of little pieces of the outside casing.
  7. Nikon Coolpix S5300  Outer Casing Replacement: adım 7, 2 resimden 1. Nikon Coolpix S5300  Outer Casing Replacement: adım 7, 2 resimden 2.
    • Carefully remove the top button casing by pulling it away from main camera.
Sonuç
Riordan McCole
307 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-1, Bhusal Spring 2016 UMass Dartmouth, Team 6-1, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S6G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 183
