Ana içeriğe geç
Nikon Coolpix S630 Battery Cover Door Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S630 Battery Cover Door Replacement, Battery Compartment: adım 1, 1 resimden 1.
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Battery Cover Door Replacement, Battery: adım 2, 1 resimden 1.
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Battery Cover Door Replacement, Memory Card: adım 3, 1 resimden 1.
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Battery Cover Door Replacement, Back Cover Removal: adım 4, 3 resimden 1. Nikon Coolpix S630 Battery Cover Door Replacement, Back Cover Removal: adım 4, 3 resimden 2. Nikon Coolpix S630 Battery Cover Door Replacement, Back Cover Removal: adım 4, 3 resimden 3.
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  5. Nikon Coolpix S630 Battery Cover Door Replacement: adım 5, 1 resimden 1.
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  6. Nikon Coolpix S630 Battery Cover Door Replacement, Detaching Ribbon: adım 6, 2 resimden 1. Nikon Coolpix S630 Battery Cover Door Replacement, Detaching Ribbon: adım 6, 2 resimden 2.
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  7. Nikon Coolpix S630 Battery Cover Door Replacement, Front Cover: adım 7, 1 resimden 1.
    • Locate a small, rectangular flap above the battery cover door.
    • Push the small, rectangular flap back through the hole.
  8. Nikon Coolpix S630 Battery Cover Door Replacement: adım 8, 1 resimden 1.
    • Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Make sure to hold the camera down when removing the front cover.
  9. Nikon Coolpix S630 Battery Cover Door Replacement, Battery Cover Door: adım 9, 1 resimden 1.
    • Locate the battery cover door.
  10. Nikon Coolpix S630 Battery Cover Door Replacement: adım 10, 2 resimden 1. Nikon Coolpix S630 Battery Cover Door Replacement: adım 10, 2 resimden 2.
    • Press and slide the cover door open.
  11. Nikon Coolpix S630 Battery Cover Door Replacement: adım 11, 1 resimden 1.
    • Locate the small rod that is securing the door in place
    • Using a tweezers, grab the rod and slowly pull the rod out
    • Note: Be careful as you try to pull the rod out because the spring may pop out
  12. Nikon Coolpix S630 Battery Cover Door Replacement: adım 12, 1 resimden 1.
    • Replace battery cover door.
    • Note: To reinstall a new battery cover door, make sure you have these parts: spring, rod, and the battery cover door.
  13. Nikon Coolpix S630 Battery Cover Door Replacement: adım 13, 1 resimden 1.
    • Place battery cover door back into place with spring between the insertion holes.
    • Using a tweezers, gently slide the rod through the insertion holes and through the spring.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aulivia Bounchaleun
10 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-56, Johann Spring 2013 Cal Poly, Team 8-56, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S8G56
4 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
I am stuck on step 8. How am I supposed to hold it down and pull the front cover off. I can only get the corner up where the battery goes.
toolshell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 1,545
