Ana içeriğe geç
Nikon Coolpix S630 Shutter Button Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S630 Shutter Button Replacement, Battery Compartment: adım 1, 1 resimden 1.
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Shutter Button Replacement, Battery: adım 2, 1 resimden 1.
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Shutter Button Replacement, Memory Card: adım 3, 1 resimden 1.
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Shutter Button Replacement, Front Cover: adım 4, 1 resimden 1.
    • Locate a small, rectangular flap above the battery cover door.
    • Push the small, rectangular flap back through the hole.
  5. Nikon Coolpix S630 Shutter Button Replacement: adım 5, 1 resimden 1.
    • Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Make sure to hold the camera down when removing the front cover.
  6. Nikon Coolpix S630 Shutter Button Replacement, Shutter Button: adım 6, 1 resimden 1.
    • Place the front cover facing down so that you can easily see the shutter button.
  7. Nikon Coolpix S630 Shutter Button Replacement: adım 7, 1 resimden 1.
    • Using tweezers, gently slide the shutter button out.
    • Be very gentle because you can damage the piece.
Sonuç
Aulivia Bounchaleun
10 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-56, Johann Spring 2013 Cal Poly, Team 8-56, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S8G56
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 2,159
