Ana içeriğe geç
Nikon Coolpix S6300 Buttons Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S6300 Buttons Replacement, Battery: adım 1, 1 resimden 1.
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Buttons Replacement: adım 2, 1 resimden 1.
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Buttons Replacement, Buttons: adım 3, 3 resimden 1. Nikon Coolpix S6300 Buttons Replacement, Buttons: adım 3, 3 resimden 2. Nikon Coolpix S6300 Buttons Replacement, Buttons: adım 3, 3 resimden 3.
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Buttons Replacement: adım 4, 3 resimden 1. Nikon Coolpix S6300 Buttons Replacement: adım 4, 3 resimden 2. Nikon Coolpix S6300 Buttons Replacement: adım 4, 3 resimden 3.
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Buttons Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Buttons Replacement: adım 6, 1 resimden 1.
    • Remove the two clasp using a plastic spudger
    • Be careful when removing the clasp to prevent ripping of the clasp
  7. Nikon Coolpix S6300 Buttons Replacement: adım 7, 1 resimden 1.
    • You may now remove the internal panel of the buttons
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Lynch
396 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Remmell Fall 2015 USF Tampa, Team 1-2, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G2
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 747
