Ana içeriğe geç
Nikon Coolpix S6300 Display Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S6300 Display Replacement, Battery: adım 1, 1 resimden 1.
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Display Replacement: adım 2, 1 resimden 1.
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Display Replacement, Buttons: adım 3, 3 resimden 1. Nikon Coolpix S6300 Display Replacement, Buttons: adım 3, 3 resimden 2. Nikon Coolpix S6300 Display Replacement, Buttons: adım 3, 3 resimden 3.
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Display Replacement: adım 4, 3 resimden 1. Nikon Coolpix S6300 Display Replacement: adım 4, 3 resimden 2. Nikon Coolpix S6300 Display Replacement: adım 4, 3 resimden 3.
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Display Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Display Replacement: adım 6, 1 resimden 1.
    • Remove the two clasp using a plastic spudger
    • Be careful when removing the clasp to prevent ripping of the clasp
  7. Nikon Coolpix S6300 Display Replacement: adım 7, 1 resimden 1.
    • You may now remove the internal panel of the buttons
  8. Nikon Coolpix S6300 Display Replacement, Display: adım 8, 1 resimden 1.
    • Remove the clasp from the ribbon cable using the plastic spudger.
    • Make sure to be gentle when removing the clasp to prevent it from ripping.
    • You may now remove the display.
Sonuç
Hung
383 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Remmell Fall 2015 USF Tampa, Team 1-2, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G2
5 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Step 8 could have better pictures and explanation of the clasp...or picture of the clasp. I think it was some white tape looking stuff that I did break. Looking for better instructions elsewhere. I think I just made the situation worse
Lisa F - Yanıt
I have this problem with my coolpix (see images and video):
https://i.postimg.cc/pXk2L4QB/20190201-1...
https://i.postimg.cc/d3wYqjLX/20190201-1...
https://i.postimg.cc/RCLmgyYz/20190201-1...
https://drive.google.com/file/d/1sDr8fPD...
Screen has a posterized effect.
I already replaced the screen with a new one, but the problem remains..
Any idea what is faulty, and how can I fix it?
Geo Nik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 18
Her zaman: 1,416
