Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide will assist you in replacing your broken, cracked or malfunctioning display screen. For this replacement you will need a Phillips #000 screwdriver and a plastic opening tool.
  1. Power off the camera before beginning. Remove the battery by sliding the latch located at the bottom of the camera.
    • Power off the camera before beginning.
    • Remove the battery by sliding the latch located at the bottom of the camera.
  2. Using a Phillips head #000 screwdriver, remove the five 0.4mm screws on the bottom of the camera. Using a Phillips head #000 screwdriver, remove the five 0.4mm screws on the bottom of the camera.
    • Using a Phillips head #000 screwdriver, remove the five 0.4mm screws on the bottom of the camera.
  3. LCD iPhone Ekran Tamir Kit'leri
    Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
    Shop Kits
    Onarım maliyetlerini düşürün, kaliteyi değil.
    Shop Kits
  4. Use a plastic opening tool to carefully separate the back panel of the camera. Once loosened, use your fingers to manually separate the two panels. Once loosened, use your fingers to manually separate the two panels.
    • Use a plastic opening tool to carefully separate the back panel of the camera.
    • Once loosened, use your fingers to manually separate the two panels.
  5. Using a plastic opening tool, lift both latches that hold the ribbon cables in place. Using a plastic opening tool, lift both latches that hold the ribbon cables in place. Using a plastic opening tool, lift both latches that hold the ribbon cables in place.
    • Using a plastic opening tool, lift both latches that hold the ribbon cables in place.
  6. Carefully disconnect the orange flat ribbon cables from the latches.
    • Carefully disconnect the orange flat ribbon cables from the latches.
  7. Remove the screen from the case of the camera by carefully pushing on the back of the screen. You may need to push with a little force to get the screen to loosen. You may need to push with a little force to get the screen to loosen.
    • Remove the screen from the case of the camera by carefully pushing on the back of the screen.
    • You may need to push with a little force to get the screen to loosen.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Danielle Morris
165 İtibar
1 Kılavuz yazıldı
Takım
Texas Tech, Team 22-2, Rauch Fall 2015 Texas Tech, Team 22-2, Rauch Fall 2015 üyesi
TTU-RAUCH-F15S22G2
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 619
