Ana içeriğe geç
Nikon Coolpix S7000 Shutter Button Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: adım 1, 2 resimden 1. Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: adım 1, 2 resimden 2.
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • Screw locations.
  2. Nikon Coolpix S7000 Shutter Button Replacement: adım 2, 2 resimden 1. Nikon Coolpix S7000 Shutter Button Replacement: adım 2, 2 resimden 2.
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Shutter Button Replacement: adım 3, 2 resimden 1. Nikon Coolpix S7000 Shutter Button Replacement: adım 3, 2 resimden 2.
    • Once the shutter button assembly is removed from the camera shell, carefully remove the black tape on the underside of the metal plate.
    • Black tape.
    • Do not discard the tape as you will reapply it when putting the shutter assembly back together.
  4. Nikon Coolpix S7000 Shutter Button Replacement: adım 4, 3 resimden 1. Nikon Coolpix S7000 Shutter Button Replacement: adım 4, 3 resimden 2. Nikon Coolpix S7000 Shutter Button Replacement: adım 4, 3 resimden 3.
    • Unscrew the two screws on each side of the metal plate to remove the plate and springs underneath it.
    • Push the button through the assembly to release it and then carefully remove the button cover to reveal the coiled spring and bottom cover.
    • Locations of the two screws.
    • Be very careful not to lose the two metal plate springs and the coiled spring when disassembling. A slow and steady hand will help prevent the springs from ejecting.
Sonuç
Ekip
USF Tampa, Team S2-G3, Lacy Spring 2017 USF Tampa, Team S2-G3, Lacy Spring 2017 üyesi
USFT-LACY-S17S2G3
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
shutter keeps trying to open. clicks slighly and does not open
Beatrix - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 29
Her zaman: 796
