Ana içeriğe geç
Nikon Coolpix S7000 Sticky Button Replacement
Neye ihtiyacın var
    • Clean your camera buttons. This can be done using isopropyl alcohol and a cotton swab. If the button is still jammed, proceed to Step 2.
  1. Nikon Coolpix S7000 Sticky Button Replacement: adım 2, 3 resimden 1. Nikon Coolpix S7000 Sticky Button Replacement: adım 2, 3 resimden 2. Nikon Coolpix S7000 Sticky Button Replacement: adım 2, 3 resimden 3.
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • 3.2mm screws (not fully threaded)
    • 3mm screws
    • 4.2mm screws (coarser thread)
  2. Nikon Coolpix S7000 Sticky Button Replacement: adım 3, 2 resimden 1. Nikon Coolpix S7000 Sticky Button Replacement: adım 3, 2 resimden 2.
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Sticky Button Replacement: adım 4, 3 resimden 1. Nikon Coolpix S7000 Sticky Button Replacement: adım 4, 3 resimden 2. Nikon Coolpix S7000 Sticky Button Replacement: adım 4, 3 resimden 3.
    • At this point push out any buttons that were jammed, and, clean the inside portion where the button sits inside the frames with isopropyl alcohol and a cotton swab as moisture may have found its way inside the camera causing stickiness.
    • Swab this portion.
  4. Nikon Coolpix S7000 Sticky Button Replacement: adım 5, 1 resimden 1.
    • If the navigation button is stuck, twist it around while the frame is removed to see if you can locate any obstructions.
    • If the shutter button is stuck, press up against it from the inside with your finger or the screwdriver to dislodge it.
  5. Nikon Coolpix S7000 Sticky Button Replacement: adım 6, 1 resimden 1.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shannon Beane
324 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G3, Lacy Spring 2017 USF Tampa, Team S2-G3, Lacy Spring 2017 üyesi
USFT-LACY-S17S2G3
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 15
Son 30 gün: 42
Her zaman: 2,506
