Giriş
The zoom unit/shutter component located inside the main body of the camera under the motherboard will need to be replaced if non-functional.
Neye ihtiyacın var
Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
Unscrew all 6 visible screws that secure the motherboard into place using a Phillips head screwdriver (found in iFixit tool kit).
Use a plastic opening tool of your choice to loosen and pry up the zoom unit/shutter component.
Use your hands to manually lift the zoom unit/shutter component up and out of the main body of the camera.
