Ana içeriğe geç
Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide
Neye ihtiyacın var
  1. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Back Panel/Touch Screen: adım 1, 2 resimden 1. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Back Panel/Touch Screen: adım 1, 2 resimden 2.
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: adım 2, 2 resimden 1. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: adım 2, 2 resimden 2.
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
  3. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Motherboard: adım 3, 1 resimden 1.
    • Unscrew all 6 visible screws that secure the motherboard into place using a Phillips head screwdriver (found in iFixit tool kit).
  4. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: adım 4, 1 resimden 1.
    • Pull the shown panel off of the motherboard to expose the Image sensor connection
  5. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: adım 5, 1 resimden 1.
    • Lift tab up to remove the Image sensor connection strip.
  6. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: adım 6, 3 resimden 1. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: adım 6, 3 resimden 2. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: adım 6, 3 resimden 3.
    • Pull the gray panels back to allow the hidden micro usb and hdmi insert connectors to come free.
    • Use a Metal Spudger to help with the process to get these connectors free from the frame.
  7. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: adım 7, 2 resimden 1. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: adım 7, 2 resimden 2.
    • Using a Metal Spudger, lift the motherboard up from the body of the camera.
  8. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: adım 8, 2 resimden 1. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: adım 8, 2 resimden 2.
    • Pull the motherboard off of the main body of the camera.
  9. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: adım 9, 3 resimden 1. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: adım 9, 3 resimden 2. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: adım 9, 3 resimden 3.
    • Use a plastic opening tool of your choice to loosen and pry up the zoom unit/shutter component.
    • Use your hands to manually lift the zoom unit/shutter component up and out of the main body of the camera.
Sonuç
Erik Knapton
222 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team S2-G6, Johnson Spring 2018 Baylor, Team S2-G6, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S2G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 304
