Giriş
Overtime, the components in a camera are likely to fail or become faulty. One component that may become faulty overtime is the screen. If your camera is not properly displaying the images you’ve taken or if there are dead pixels on your screen, the screen may need to be replaced. This guide will assist you in replacing the LCD Screen on the Nikon Coolpix S9050.
Neye ihtiyacın var
Remove the screws. There are two on each side, and four on the bottom. The black screws are 3.2 mm Phillips #000. The silver screws are also 3.2 mm Phillips #000.
Remove the silver 3.2 mm Phillips #000 screw on the corner of the device to remove the screen.
