Ana içeriğe geç
Nikon Coolpix S9050 Menu Wheel and OK Button Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement, Menu Wheel and OK Button: adım 1, 3 resimden 1. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement, Menu Wheel and OK Button: adım 1, 3 resimden 2. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement, Menu Wheel and OK Button: adım 1, 3 resimden 3.
    • Remove the screws. There are two on each side, and four on the bottom. The black screws are 3.2 mm Phillips #000. The silver screws are also 3.2 mm Phillips #000.
  2. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: adım 2, 1 resimden 1.
    • Remove the screen housing and trim piece.
  3. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: adım 3, 3 resimden 1. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: adım 3, 3 resimden 2. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: adım 3, 3 resimden 3.
    • Press down and pull the Menu Wheel/OK Button panel towards the screen. This will release the panel from the slots.
  4. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: adım 4, 3 resimden 1. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: adım 4, 3 resimden 2. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: adım 4, 3 resimden 3.
    • Lift up on the black plastic tab(zero insertion force connector-ZIF) and gently pull the panel out to detach the ribbon cable from the camera body.
Sonuç
Catrionna Bruce
205 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G3, Harley Fall 2018 IUPUI, Team S3-G3, Harley Fall 2018 üyesi
IUPUI-HARLEY-F18S3G3
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 462
