Ana içeriğe geç
Nikon Coolpix S9700 Back Panel Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S9700 Back Panel Replacement, Battery: adım 1, 2 resimden 1. Nikon Coolpix S9700 Back Panel Replacement, Battery: adım 1, 2 resimden 2.
    • Press the ON/OFF button to power off the S9700.
    • Not doing so can damage the S9700 or cause electric shock.
  2. Nikon Coolpix S9700 Back Panel Replacement: adım 2, 3 resimden 1. Nikon Coolpix S9700 Back Panel Replacement: adım 2, 3 resimden 2. Nikon Coolpix S9700 Back Panel Replacement: adım 2, 3 resimden 3.
    • Place the S9700 upside down
    • Place your finger on the battery compartment cover and gently push toward the front of the S9700.
    • The cover will open up by itself.
  3. Nikon Coolpix S9700 Back Panel Replacement: adım 3, 3 resimden 1. Nikon Coolpix S9700 Back Panel Replacement: adım 3, 3 resimden 2. Nikon Coolpix S9700 Back Panel Replacement: adım 3, 3 resimden 3.
    • Push the yellow tab inside the battery compartment in the direction of the arrow. This will allow the battery to spring up.
  4. Nikon Coolpix S9700 Back Panel Replacement: adım 4, 2 resimden 1. Nikon Coolpix S9700 Back Panel Replacement: adım 4, 2 resimden 2.
    • Grab the battery and pull out.
  5. Nikon Coolpix S9700 Back Panel Replacement, Back Panel: adım 5, 2 resimden 1. Nikon Coolpix S9700 Back Panel Replacement, Back Panel: adım 5, 2 resimden 2.
    • Remove the two 4-mm and three 3-mm J000 screws from the bottom of the S9700.
    • Three 3-mm screws are on the side opposite the battery compartment.
    • Two 4-mm screws are on the side with the battery compartment. One of these screws is in the battery compartment. Open it up for access.
  6. Nikon Coolpix S9700 Back Panel Replacement: adım 6, 2 resimden 1. Nikon Coolpix S9700 Back Panel Replacement: adım 6, 2 resimden 2.
    • Remove the one 3-mm J000 screw on the left side of the S9700 (side with no ports).
    • Remove the two 3-mm J000 screws on the right side (side with HDMI and charging ports).
    • One of these screws is underneath the HDMI port cover. Lift the port cover up to access.
  7. Nikon Coolpix S9700 Back Panel Replacement: adım 7, 3 resimden 1. Nikon Coolpix S9700 Back Panel Replacement: adım 7, 3 resimden 2. Nikon Coolpix S9700 Back Panel Replacement: adım 7, 3 resimden 3.
    • Insert the plastic opening tool on the bottom of the S9700 between the front panel and the back panel.
    • Twist the plastic opening tool so that both halves separate.
    • When both halves are separated, the HDMI cover, charging cover, and the ON/OFF switch will fall out.
    • There is a flex ribbon attached to the back panel. Forcing the back panel off may rip it.
  8. Nikon Coolpix S9700 Back Panel Replacement: adım 8, 3 resimden 1. Nikon Coolpix S9700 Back Panel Replacement: adım 8, 3 resimden 2. Nikon Coolpix S9700 Back Panel Replacement: adım 8, 3 resimden 3.
    • Remove the three silver 3-mm J000 screws on the back panel holding the silver button / dial component to the panel and ribbon.
    • Gently remove the back panel.
Sonuç
Matt Staubus
849 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-5, Lacy Fall 2016 USF Tampa, Team 9-5, Lacy Fall 2016 üyesi
USFT-LACY-F16S9G5
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,120
