Ana içeriğe geç
Nikon D3100 Lens Mounting Ring Reseating/Replacement
Neye ihtiyacın var
  1. Nikon D3100 Lens Mounting Ring Reseating/Replacement, Lens Mounting Ring: adım 1, 1 resimden 1.
    • Remove the 6 Phillips screws on the front of the lens mounting ring.
  2. Nikon D3100 Lens Mounting Ring Reseating/Replacement: adım 2, 1 resimden 1.
    • Carefully lift the mounting ring straight up.
    • Three unfastened metal plates lie under the lens mounting ring, be very careful lifting it up as to not disturb them.
  3. Nikon D3100 Lens Mounting Ring Reseating/Replacement: adım 3, 2 resimden 1. Nikon D3100 Lens Mounting Ring Reseating/Replacement: adım 3, 2 resimden 2.
    • Reseat or replace the lens mounting ring and reassemble.
    • The locating pin on the right of the camera will help place the mounting ring properly.
    • The small metal plates marked in the image are not fastened and may displace if the camera if tipped or bumped. Be sure these are properly in place before reassembly.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Taylor
1.189 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Watkins Winter 2015 USF Tampa, Team 16-6, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S16G6
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 41
Her zaman: 4,372
