Ana içeriğe geç
Nikon D40 Flash Pin Replacement
Neye ihtiyacın var
  1. Nikon D40 Flash Pin Replacement, Flash Pin: adım 1, 1 resimden 1.
    • Turn off the camera and remove the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Nikon D40 Flash Pin Replacement: adım 2, 1 resimden 1.
    • Pry the flash open using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  3. Nikon D40 Flash Pin Replacement: adım 3, 1 resimden 1.
    • Remove the two Phillips #0 3.0 mm screws from the front of the flash compartment using the small Phillips Head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Nikon D40 Flash Pin Replacement: adım 4, 2 resimden 1. Nikon D40 Flash Pin Replacement: adım 4, 2 resimden 2.
    • Pry off the back plastic of the flash compartment using the plastic opening tool.
    • When it is time to reassemble the flash module, a certain amount of force and precise alignment will be required.
    FixBot'a Sor
    Yorum Ekle
  5. Nikon D40 Flash Pin Replacement: adım 5, 2 resimden 1. Nikon D40 Flash Pin Replacement: adım 5, 2 resimden 2.
    • On the left of the camera you will see a metal spring.
    • Unscrew the Phillips #0 3.0 mm screw holding the spring in place, using the small Phillips Head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Nikon D40 Flash Pin Replacement: adım 6, 1 resimden 1.
    • Remove metal spring and replace with new spring.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Lindsey Chase
227 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-19, Maness Winter 2014 Cal Poly, Team 6-19, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G19
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 48
Her zaman: 4,634
