Ana içeriğe geç
Nikon D40 LCD Screen Replacement
Neye ihtiyacın var
  1. Nikon D40 LCD Screen Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
    FixBot'a Sor
    Yorum Ekle
  2. Nikon D40 LCD Screen Replacement: adım 2, 2 resimden 1. Nikon D40 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
    FixBot'a Sor
    Yorum Ekle
  3. Nikon D40 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
    FixBot'a Sor
    Yorum Ekle
  4. Nikon D40 LCD Screen Replacement: adım 4, 1 resimden 1.
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
    FixBot'a Sor
    Yorum Ekle
  5. Nikon D40 LCD Screen Replacement, LCD Screen: adım 5, 1 resimden 1.
    • Remove the six 3.0 mm Philips #0 screws on the inside of the back panel which contains the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  6. Nikon D40 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Detach the ribbon cables on the LCD casing.
    FixBot'a Sor
    Yorum Ekle
  7. Nikon D40 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Remove the metal casing containing the LCD screen using the plastic opening tool.
    • Be sure to look at the picture to make sure you are removing the correct piece of metal. There should be no glue holding the correct piece to the frame.
    FixBot'a Sor
    Yorum Ekle
  8. Nikon D40 LCD Screen Replacement: adım 8, 1 resimden 1.
    • You should now be able to remove the LCD screen. Replace it with a new screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Gerik Kubiak
327 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-19, Maness Winter 2014 Cal Poly, Team 6-19, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G19
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 62
Her zaman: 7,100
