Ana içeriğe geç
Nikon D40 Mainboard Replacement
Neye ihtiyacın var
  1. Nikon D40 Mainboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
    FixBot'a Sor
    Yorum Ekle
  2. Nikon D40 Mainboard Replacement: adım 2, 2 resimden 1. Nikon D40 Mainboard Replacement: adım 2, 2 resimden 2.
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
    FixBot'a Sor
    Yorum Ekle
  3. Nikon D40 Mainboard Replacement: adım 3, 1 resimden 1.
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
    FixBot'a Sor
    Yorum Ekle
  4. Nikon D40 Mainboard Replacement: adım 4, 1 resimden 1.
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
    FixBot'a Sor
    Yorum Ekle
  5. Nikon D40 Mainboard Replacement, Mainboard: adım 5, 2 resimden 1. Nikon D40 Mainboard Replacement, Mainboard: adım 5, 2 resimden 2.
    • Remove the solder connecting the red wire to the mainboard.
    FixBot'a Sor
    Yorum Ekle
  6. Nikon D40 Mainboard Replacement: adım 6, 1 resimden 1.
    • Desolder the 4 smaller wires near the bottom of the mainboard.
    FixBot'a Sor
    Yorum Ekle
  7. Nikon D40 Mainboard Replacement: adım 7, 2 resimden 1. Nikon D40 Mainboard Replacement: adım 7, 2 resimden 2.
    • Use the plastic opening tool to release the ribbon cables attached to the mainboard.
    FixBot'a Sor
    Yorum Ekle
  8. Nikon D40 Mainboard Replacement: adım 8, 1 resimden 1.
    • Remove the five 3.0mm Philips #1 screws holding the mainboard down.
    FixBot'a Sor
    Yorum Ekle
  9. Nikon D40 Mainboard Replacement: adım 9, 2 resimden 1. Nikon D40 Mainboard Replacement: adım 9, 2 resimden 2.
    • Lift the mainboard up to reveal the final connection.
    • Carefully detach the white cable from the board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Joe Leija
632 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-19, Maness Winter 2014 Cal Poly, Team 6-19, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G19
4 Üyeler
7 adet Kılavuz yazıldı
3Kılavuz Yorumları
What is the ordering of the small wires on the bottom? It is hard to put back together from the photos. Thanks!
Joseph Ruskiewicz - Yanıt Paylaş
wheres the power source? i mean the fuse
Gringo Maputi - Yanıt Paylaş
in the main board located kindly put markings on it
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 51
Her zaman: 5,168
