Ana içeriğe geç
Nikon D40 Viewfinder Replacement
Neye ihtiyacın var
  1. Nikon D40 Viewfinder Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
    FixBot'a Sor
    Yorum Ekle
  2. Nikon D40 Viewfinder Replacement: adım 2, 2 resimden 1. Nikon D40 Viewfinder Replacement: adım 2, 2 resimden 2.
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
    FixBot'a Sor
    Yorum Ekle
  3. Nikon D40 Viewfinder Replacement: adım 3, 1 resimden 1.
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
    FixBot'a Sor
    Yorum Ekle
  4. Nikon D40 Viewfinder Replacement: adım 4, 1 resimden 1.
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
    FixBot'a Sor
    Yorum Ekle
  5. Nikon D40 Viewfinder Replacement, Viewfinder: adım 5, 1 resimden 1.
    • You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
    • Be careful not to pull too hard on the ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  6. Nikon D40 Viewfinder Replacement: adım 6, 1 resimden 1.
    • Slowly push the upper body up until you see the frame of the viewfinder
    • Be careful while pulling the top camera body.
    FixBot'a Sor
    Yorum Ekle
  7. Nikon D40 Viewfinder Replacement: adım 7, 1 resimden 1.
    • Use a spudger to keep the upper body separate from the printed circuit board.
    • Wiggle the plastic eyepiece out of the frame. This may require some force.
    FixBot'a Sor
    Yorum Ekle
  8. Nikon D40 Viewfinder Replacement: adım 8, 1 resimden 1.
    • Remove the viewfinder with the plastic opening tool.
    • Do not push too hard while using the opening tool.
    FixBot'a Sor
    Yorum Ekle
  9. Nikon D40 Viewfinder Replacement: adım 9, 1 resimden 1.
    • The viewfinder has been removed!
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Amy Chen
193 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-19, Maness Winter 2014 Cal Poly, Team 6-19, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G19
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 40
Her zaman: 4,023
