Neye ihtiyacın var
Unscrew the eight Phillips #00 screws on the back panel:
Two 2.5x6mm screws above the screen.
One 3x6mm screw on the upper part of each side (two total; right side shown).
One 3x7.5mm screw on the lower part of each side (two total).
Two 3x4.5mm screws on the bottom.
Bu adımda kullanılan alet:Tweezers$4.99
Pull the back panel up, then tilt it back. There will be two cables still holding it on.
Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
