Ana içeriğe geç
Nikon D5000 Speaker Replacement
Neye ihtiyacın var
  1. Nikon D5000 Speaker Replacement, Back Panel: adım 1, 3 resimden 1. Nikon D5000 Speaker Replacement, Back Panel: adım 1, 3 resimden 2. Nikon D5000 Speaker Replacement, Back Panel: adım 1, 3 resimden 3.
    • The battery door has been removed for clarity, but is not necessary. See this guide for how to remove it.
    • Unscrew the eight Phillips #00 screws on the back panel:
    • Two 2.5x6mm screws above the screen.
    • One 3x6mm screw on the upper part of each side (two total; right side shown).
    • One 3x7.5mm screw on the lower part of each side (two total).
    • Two 3x4.5mm screws on the bottom.
  2. Nikon D5000 Speaker Replacement: adım 2, 3 resimden 1. Nikon D5000 Speaker Replacement: adım 2, 3 resimden 2. Nikon D5000 Speaker Replacement: adım 2, 3 resimden 3.
    • Pull the back panel up, then tilt it back. There will be two cables still holding it on.
    • Doing this will also release the connector cover on the left side. Set it aside for now, but remember to reinstall it later.
    • Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
    • This procedure also applies to all of the other ribbon cables in the D5000.
    • Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
  3. Nikon D5000 Speaker Replacement, Speaker: adım 3, 2 resimden 1. Nikon D5000 Speaker Replacement, Speaker: adım 3, 2 resimden 2.
    • The speaker is mounted to the underside of the back panel. There is a a metal shield that holds it on.
    • Remove the four Phillips #00 screws securing the shield:
    • Three silver 3x4mm screws.
    • One black 3x3mm screw.
    • Remove the shield.
    • With the shield off, the navigation buttons and "Lv" button are free to move and rotate. Check alignment before replacement.
  4. Nikon D5000 Speaker Replacement: adım 4, 1 resimden 1.
    • Lift the blue tape on the ribbon cable.
    • Desolder the two leads to the speaker.
  5. Nikon D5000 Speaker Replacement: adım 5, 1 resimden 1.
    • Pry the speaker out of its cavity.
Sonuç
Jacob Rardin
1.390 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-28, Maness Spring 2014 Cal Poly, Team 13-28, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G28
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 939
