Ana içeriğe geç
Nikon D5100 Battery Door Replacement
Neye ihtiyacın var
  1. Nikon D5100 Battery Door Replacement, Battery Door: adım 1, 3 resimden 1. Nikon D5100 Battery Door Replacement, Battery Door: adım 1, 3 resimden 2. Nikon D5100 Battery Door Replacement, Battery Door: adım 1, 3 resimden 3.
    • Insert the battery into the battery compartment at the bottom of the camera.
  2. Nikon D5100 Battery Door Replacement: adım 2, 3 resimden 1. Nikon D5100 Battery Door Replacement: adım 2, 3 resimden 2. Nikon D5100 Battery Door Replacement: adım 2, 3 resimden 3.
    • Take the mending plate and place it over the threaded hole at the bottom of the camera.
    • Make sure the mending plate is covering the battery compartment.
    • Hold the mending plate in position.
  3. Nikon D5100 Battery Door Replacement: adım 3, 3 resimden 1. Nikon D5100 Battery Door Replacement: adım 3, 3 resimden 2. Nikon D5100 Battery Door Replacement: adım 3, 3 resimden 3.
    • While holding down the mending plate, take the screw and place it on top of the mending plate and over the threaded hole.
    • Push the screw into the threaded hole and turn clockwise to screw in.
    • Tighten the screw by using a screwdriver.
  4. Nikon D5100 Battery Door Replacement: adım 4, 1 resimden 1.
    • The metal bar should be attached and tightly secured.
  5. Nikon D5100 Battery Door Replacement: adım 5, 2 resimden 1. Nikon D5100 Battery Door Replacement: adım 5, 2 resimden 2.
    • Turn on the camera to check that the battery is properly secure.
Bitiş Çizgisi
Michelle Tran
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 23-1, Green Winter 2015 Cal Poly, Team 23-1, Green Winter 2015 üyesi
CPSU-GREEN-W15S23G1
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
My son broke the battery door and I kept it somewhere now it's gone
Chiaki - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 27
Her zaman: 2,783
