Ana içeriğe geç
Nikon D5200 Screen Replacement
Neye ihtiyacın var
  1. Nikon D5200 Screen Replacement, Screen: adım 1, 3 resimden 1. Nikon D5200 Screen Replacement, Screen: adım 1, 3 resimden 2. Nikon D5200 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Fully open the LCD panel so that its screws are easily accessible.
    • Remove the two 2.5 mm screws from the outside edge of the screen casing, and the two 3.5 mm screws from the inside edge.
  2. Nikon D5200 Screen Replacement: adım 2, 3 resimden 1. Nikon D5200 Screen Replacement: adım 2, 3 resimden 2. Nikon D5200 Screen Replacement: adım 2, 3 resimden 3.
    • Pry open the plastic casing using the opening tool or by hand.
  3. Nikon D5200 Screen Replacement: adım 3, 3 resimden 1. Nikon D5200 Screen Replacement: adım 3, 3 resimden 2. Nikon D5200 Screen Replacement: adım 3, 3 resimden 3.
    • Use the plastic opening tool to pop up the latch holding the ribbon cable on the right side of the circuit board, and remove it.
    • Use the plastic opening tool to pry the ribbon cable on the left side of the circuit board up and off of its socket.
  4. Nikon D5200 Screen Replacement: adım 4, 2 resimden 1. Nikon D5200 Screen Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, unplug the smaller cable.
  5. Nikon D5200 Screen Replacement: adım 5, 2 resimden 1. Nikon D5200 Screen Replacement: adım 5, 2 resimden 2.
    • Desolder the three small wires on the left side of the circuit board.
    • Soldering irons become very hot when in use. Take all necessary precautions to avoid injury.
  6. Nikon D5200 Screen Replacement: adım 6, 3 resimden 1. Nikon D5200 Screen Replacement: adım 6, 3 resimden 2. Nikon D5200 Screen Replacement: adım 6, 3 resimden 3.
    • Using a spudger, remove the display from its casing.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Alexander Corn
1.319 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Eyestone Fall 2015 USF Tampa, Team 3-1, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S3G1
4 Üyeler
11Kılavuz Yorumları
Do I need to de-solder if I'm just replacing the window glass?
isaac - Yanıt
To isaac: no. The exterior glass is separate from the LCD.
Joseph Morris - Yanıt
Do you recommend the replacent for LCD sold on Ebay?
g_atki - Yanıt
Where did you find the replacement screen? The one I ordered that says it's for the d5200 is not the same as the one in it or in your pictures.
Heather Miller - Yanıt
How do you disconnect the multi-plug that is shown connected in image 4 and disconnected in image five? Does it unclip or slide out?
Amanda Bruyninckx - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 76
Her zaman: 13,306
