Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Remove the rear cover assembly to access the LCD and other components.
Neye ihtiyacın var
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
11 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thanks for the instructions, but I’m an old man (74) with not much strength these days, and so I am having MUCH difficulty removing these TINY screws even with a jeweler’s screwdriver (the smallest Phillips driver I have. I’ll have to look for a smaller set of screwdrivers, and perhaps a younger, stronger, more adept person to help.
But thanks for the instructions and for the knowhow. MY specialties are writing (awards for writing), photography (awards for photography), acting, poetry, computer building/repair, and so on.
Thanks again.
John Weatherly, Seattle, WA
