Ana içeriğe geç
Nikon D700 Screen Replacement
  1. Nikon D700 Screen Replacement, Screen: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    iOpener
    $17.99
    • Use a spudger and your hands to remove the front grip cover, held together by an adhesive.
    • You may need to use heat to loosen up the adhesive. Try using the iOpener.
    • Under the rubber cover, use a screwdriver to remove one screw on the top right corner.
  2. Nikon D700 Screen Replacement: adım 2, 2 resimden 1. Nikon D700 Screen Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the five screws that hold the cover in place.
  3. Nikon D700 Screen Replacement: adım 3, 1 resimden 1.
    • Gently remove the screen by pulling the top away from the body.
    • The screen is connected by wires on the bottom, so be careful when taking the screen off.
  4. Nikon D700 Screen Replacement: adım 4, 3 resimden 1. Nikon D700 Screen Replacement: adım 4, 3 resimden 2. Nikon D700 Screen Replacement: adım 4, 3 resimden 3.
    • To remove the screen entirely, use a spudger to unlock the connectors.
    • Pull the cables out gently using tweezers or your spudger.
  5. Nikon D700 Screen Replacement: adım 5, 2 resimden 1. Nikon D700 Screen Replacement: adım 5, 2 resimden 2.
    • The screen should be completely detached from the camera and can now be replaced with a new screen.
Sonuç
Leandro Neves
227 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-4, Ramos Spring 2023 UMass Dartmouth, Team 5-4, Ramos Spring 2023 üyesi
UMASSD-RAMOS-S23S5G4
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 97
Her zaman: 1,444
