Ana içeriğe geç
Nikon D7000 Motherboard Replacement
Neye ihtiyacın var
  1. Nikon D7000 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Motherboard Replacement: adım 3, 2 resimden 1. Nikon D7000 Motherboard Replacement: adım 3, 2 resimden 2.
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Motherboard Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Motherboard Replacement: adım 7, 1 resimden 1.
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Motherboard Replacement: adım 9, 1 resimden 1.
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Motherboard Replacement: adım 11, 1 resimden 1.
    • Gently pull the SD card cover off.
  12. Nikon D7000 Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Motherboard Replacement: adım 13, 1 resimden 1.
    • Carefully lift the back case off.
  14. Nikon D7000 Motherboard Replacement: adım 14, 3 resimden 1. Nikon D7000 Motherboard Replacement: adım 14, 3 resimden 2. Nikon D7000 Motherboard Replacement: adım 14, 3 resimden 3.
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Motherboard Replacement: adım 15, 2 resimden 1. Nikon D7000 Motherboard Replacement: adım 15, 2 resimden 2.
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Motherboard Replacement: adım 16, 1 resimden 1.
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Motherboard Replacement: adım 18, 1 resimden 1.
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Motherboard Replacement: adım 19, 3 resimden 1. Nikon D7000 Motherboard Replacement: adım 19, 3 resimden 2. Nikon D7000 Motherboard Replacement: adım 19, 3 resimden 3.
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Motherboard Replacement: adım 20, 2 resimden 1. Nikon D7000 Motherboard Replacement: adım 20, 2 resimden 2.
  21. Nikon D7000 Motherboard Replacement: adım 21, 1 resimden 1.
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Motherboard Replacement: adım 22, 1 resimden 1.
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Motherboard Replacement: adım 23, 1 resimden 1.
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Motherboard Replacement: adım 24, 1 resimden 1.
    • Lift the motherboard off.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Jed Chen
1.808 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S24G6
3 Üyeler
5 adet Kılavuz yazıldı
5 Yorum
Hi thank you.
winnaingsoe - Yanıt
perfekt. Thank you! Had to replace the board because the GPS port was brocken.
Georges Hamlet - Yanıt
Hi, thanks for the detailed instructions! I just replaced my main board and the new one did not boot. The battery is charged, but the LCD shows nothing when battery is in and when the power is on. Is that a problem with the replacement main board or does it need to be programmed? I expected it to power up once the power is available.
serget - Yanıt
Have you resolved your issue?
Bhaskar vedula -
I get CLOCK with low battery indication . I checked internal battery health and I replaced with new battery on motherboard . Now with new battery in place I see voltage 3.12v and still camera does show CLOCK symbols with low battery. Please let me know if there is hard reset makes default configuration.
Bhaskar vedula - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 6,227
