Ana içeriğe geç
Nikon D7000 Shutter Assembly Replacement
Neye ihtiyacın var
  1. Nikon D7000 Shutter Assembly Replacement, Motherboard: adım 1, 1 resimden 1.
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Shutter Assembly Replacement: adım 2, 1 resimden 1.
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Shutter Assembly Replacement: adım 3, 2 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 3, 2 resimden 2.
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Shutter Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Shutter Assembly Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Shutter Assembly Replacement: adım 6, 1 resimden 1.
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Shutter Assembly Replacement: adım 7, 1 resimden 1.
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Shutter Assembly Replacement: adım 8, 1 resimden 1.
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Shutter Assembly Replacement: adım 9, 1 resimden 1.
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Shutter Assembly Replacement: adım 10, 1 resimden 1.
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Shutter Assembly Replacement: adım 11, 1 resimden 1.
    • Gently pull the SD card cover off.
  12. Nikon D7000 Shutter Assembly Replacement: adım 12, 1 resimden 1.
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Shutter Assembly Replacement: adım 13, 1 resimden 1.
    • Carefully lift the back case off.
  14. Nikon D7000 Shutter Assembly Replacement: adım 14, 3 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 14, 3 resimden 2. Nikon D7000 Shutter Assembly Replacement: adım 14, 3 resimden 3.
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Shutter Assembly Replacement: adım 15, 2 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 15, 2 resimden 2.
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Shutter Assembly Replacement: adım 16, 1 resimden 1.
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Shutter Assembly Replacement: adım 17, 1 resimden 1.
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Shutter Assembly Replacement: adım 18, 1 resimden 1.
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Shutter Assembly Replacement: adım 19, 3 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 19, 3 resimden 2. Nikon D7000 Shutter Assembly Replacement: adım 19, 3 resimden 3.
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Shutter Assembly Replacement: adım 20, 2 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 20, 2 resimden 2.
  21. Nikon D7000 Shutter Assembly Replacement: adım 21, 1 resimden 1.
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Shutter Assembly Replacement: adım 22, 1 resimden 1.
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Shutter Assembly Replacement: adım 23, 1 resimden 1.
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Shutter Assembly Replacement: adım 24, 1 resimden 1.
    • Lift the motherboard off.
  25. Nikon D7000 Shutter Assembly Replacement, Tripod Plate: adım 25, 1 resimden 1.
    • Remove four 6 mm J000 screws securing the tripod plate.
  26. Nikon D7000 Shutter Assembly Replacement: adım 26, 1 resimden 1.
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
  27. Nikon D7000 Shutter Assembly Replacement, Image Sensor: adım 27, 2 resimden 1. Nikon D7000 Shutter Assembly Replacement, Image Sensor: adım 27, 2 resimden 2.
    • Disconnect black and white speaker cable.
  28. Nikon D7000 Shutter Assembly Replacement: adım 28, 1 resimden 1.
    • Remove three 6 mm J000 screws securing the image sensor.
  29. Nikon D7000 Shutter Assembly Replacement: adım 29, 1 resimden 1.
    • Carefully lift the image sensor plate out of the camera.
  30. Nikon D7000 Shutter Assembly Replacement, Shutter Assembly: adım 30, 1 resimden 1.
    • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
    • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
  31. Nikon D7000 Shutter Assembly Replacement: adım 31, 1 resimden 1.
    • Remove two 5 mm J000 screws from under the flash.
  32. Nikon D7000 Shutter Assembly Replacement: adım 32, 1 resimden 1.
    • Remove two 3 mm J000 screws securing the front cover.
  33. Nikon D7000 Shutter Assembly Replacement: adım 33, 2 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 33, 2 resimden 2.
    • Remove the front cover.
  34. Nikon D7000 Shutter Assembly Replacement: adım 34, 1 resimden 1.
    • Carefully remove the port cover.
  35. Nikon D7000 Shutter Assembly Replacement: adım 35, 1 resimden 1.
    • Deroute the microphone cable.
  36. Nikon D7000 Shutter Assembly Replacement: adım 36, 1 resimden 1.
    • Remove one 4 mm J000 screw from the front.
  37. Nikon D7000 Shutter Assembly Replacement: adım 37, 1 resimden 1.
    • Remove one 8.5 mm J000 screw from the battery compartment.
  38. Nikon D7000 Shutter Assembly Replacement: adım 38, 1 resimden 1.
    • Remove the grip carefully.
  39. Nikon D7000 Shutter Assembly Replacement: adım 39, 1 resimden 1.
    • Remove one 4 mm J000 screw securing the top case (under right strap hook).
  40. Nikon D7000 Shutter Assembly Replacement: adım 40, 1 resimden 1.
    • Remove one 4 mm J000 screw securing the top case (under left strap hook).
  41. Nikon D7000 Shutter Assembly Replacement: adım 41, 1 resimden 1.
    • Remove the sticker covering the diopter adjust screw.
  42. Nikon D7000 Shutter Assembly Replacement: adım 42, 1 resimden 1.
    • Remove one 8.0 mm J000 screw.
    • Remove the Diopeter Adjust.
  43. Nikon D7000 Shutter Assembly Replacement: adım 43, 1 resimden 1.
    • Remove the top case.
  44. Nikon D7000 Shutter Assembly Replacement: adım 44, 1 resimden 1.
    • Remove the Black, Yellow, Green cable from the top case board.
  45. Nikon D7000 Shutter Assembly Replacement: adım 45, 3 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 45, 3 resimden 2. Nikon D7000 Shutter Assembly Replacement: adım 45, 3 resimden 3.
    • Remove two 6.5 mm J000 screws securing the viewfinder.
    • Remove the viewfinder cover.
  46. Nikon D7000 Shutter Assembly Replacement: adım 46, 1 resimden 1.
    • Remove one 3 mm J000 screw from the bottom left side of the camera.
  47. Nikon D7000 Shutter Assembly Replacement: adım 47, 1 resimden 1.
    • Remove two 6 mm J000 screws from the left of the shutter.
  48. Nikon D7000 Shutter Assembly Replacement: adım 48, 1 resimden 1.
    • Remove two 6.5 mm J000 screws from beneath the lens mount.
  49. Nikon D7000 Shutter Assembly Replacement: adım 49, 1 resimden 1.
    • Remove two screws from just below and to the sides of the viewfinder.
  50. Nikon D7000 Shutter Assembly Replacement: adım 50, 1 resimden 1.
    • Remove one 5 mm J000 screw from the top right of the camera.
  51. Nikon D7000 Shutter Assembly Replacement: adım 51, 1 resimden 1.
    • Carefully peel back ribbon cable on the bottom left of camera.
  52. Nikon D7000 Shutter Assembly Replacement: adım 52, 2 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 52, 2 resimden 2.
    • Remove the left front ribbon cable from top right of circuit board.
  53. Nikon D7000 Shutter Assembly Replacement: adım 53, 1 resimden 1.
    • Remove all three wire connectors.
  54. Nikon D7000 Shutter Assembly Replacement: adım 54, 1 resimden 1.
    • Separate the shutter assembly from the camera body.
Sonuç
35 farklı kişi bu kılavuzu tamamladı.
Steven Castaneda
691 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S24G6
3 Üyeler
5 adet Kılavuz yazıldı
10Kılavuz Yorumları
Use a #00 Philips, not a #0, or you'll strip the screws. Also, there are two or three screws connecting the shutter assembly to the camera body, and its contacts are soldered on. So you need a soldering iron for the last step.
Michael Duncan - Yanıt
im gonna be trying this soon , how long did it take and how difficult is it ,,,
Dean Wilkinson - Yanıt
Guide not completed. Last step only shows removal of mirror box. Shutter assembly replacement not
Ziyang - Yanıt
Regardless of possibly a few missing steps, this is a great lesson of how to deal with shutter replacement on my own. Hats off !!
Mateusz Witek - Yanıt
How to reassemble diopter adjustment?
Jerome - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 30
Son 30 gün: 112
Her zaman: 19,688
