Ana içeriğe geç
Nikon D7000 Shutter Assembly Replacement
Neye ihtiyacın var
  1. Nikon D7000 Shutter Assembly Replacement, Motherboard: adım 1, 1 resimden 1.
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
    Note for D7100: the rightmost screw marked red is 5.4mm long (to the right of the identification sticker with serial number), the 3 other screws marked red are 6.0mm long. The orange screw is 8.75mm long.
    Olivier Biot - Yanıt
  2. Nikon D7000 Shutter Assembly Replacement: adım 2, 1 resimden 1.
    • Remove three 6 mm J000 screws from under the battery cover.
    Note for D7100: the screw marked red closest to the yellow battery guarding clip is 5.3mm long, the 2 other screws marked red are 6.0mm long.
  3. Nikon D7000 Shutter Assembly Replacement: adım 3, 2 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 3, 2 resimden 2.
    • Gently pull the bottom cover off of the camera body.
    Note for D7100: place your thumb in the battery compartment and your index outside the battery box. Gently pinch the bottom cover between thumb and index finger, and gently lift it from the camera body. It separates very easily.
  4. Nikon D7000 Shutter Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
    Note for D7100: the 2 screws marked red under the rubber covers are hidden below the middle cover. These screws are 3.8mm long. The orange screw is 6.35mm long.
  5. Nikon D7000 Shutter Assembly Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Peel the rear rubber piece off with tweezers.
    This is not needed : if you don't touch this rubber & screw the SD card cover will come off at the same time that the back case.
    = Quicker and easier
    Xavier - Yanıt
  6. Nikon D7000 Shutter Assembly Replacement: adım 6, 1 resimden 1.
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
    Xavier - Yanıt
    ⚠️ Note for D7100: this step IS needed when disassembling the D7100 body as the rubber conceals 2 JIS #000 screws (5.5 mm at top and 3 mm at bottom). Without removing those 2 screws the back case won't separate from the body. When detaching the rubber cover, make sure to keep the small plastic cover embedded at the bottom of the rubber.
    The SD card cover will fall out from the camera body when separating the back case.
  7. Nikon D7000 Shutter Assembly Replacement: adım 7, 1 resimden 1.
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Shutter Assembly Replacement: adım 8, 1 resimden 1.
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
    Concerning the diopter, it's wrong : D7000 also have a screw in it.
    See step 41.
    Xavier - Yanıt
    Note for D7100: the 2 screws to the side of the eyepiece are 5.3mm long.
    Note for D7100: the screw holding the diopter dial is 11.4mm long.
  9. Nikon D7000 Shutter Assembly Replacement: adım 9, 1 resimden 1.
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Shutter Assembly Replacement: adım 10, 1 resimden 1.
    • Remove four 6 mm J000 screws that secure the SD card cover.
    Note for D7100: these 4 screws are 6.30-6.35mm long
  11. Nikon D7000 Shutter Assembly Replacement: adım 11, 1 resimden 1.
    • Gently pull the SD card cover off.
    Attention! High voltage. After removing the memory card cover, remove the yellow sticker and use a 220 volt 15 watt incandescent lamp to discharge the capacitor.
    Rust Twentyone - Yanıt
  12. Nikon D7000 Shutter Assembly Replacement: adım 12, 1 resimden 1.
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
    On D7100 both screws are the same length at 6mm
    Simon Tullett - Yanıt
  13. Nikon D7000 Shutter Assembly Replacement: adım 13, 1 resimden 1.
    • Carefully lift the back case off.
  14. Nikon D7000 Shutter Assembly Replacement: adım 14, 3 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 14, 3 resimden 2. Nikon D7000 Shutter Assembly Replacement: adım 14, 3 resimden 3.
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
    Note for D7100: the 2 ribbon cables that connect the back cover to the motherboard have ZIF sockets with the black lever at the bottom. Leave the other 2 (leftmost) ribbon cables at the bottom of the motherboard untouched.
  15. Nikon D7000 Shutter Assembly Replacement: adım 15, 2 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 15, 2 resimden 2.
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Shutter Assembly Replacement: adım 16, 1 resimden 1.
    • Gently pry and lift the left motherboard shield off.
    No need to remove shield. Risk of damaging clips holding shield.
    Ziyang - Yanıt
    No Motherboard shield on D7100
  17. Nikon D7000 Shutter Assembly Replacement: adım 17, 1 resimden 1.
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
    Ziyang - Yanıt
  18. Nikon D7000 Shutter Assembly Replacement: adım 18, 1 resimden 1.
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Shutter Assembly Replacement: adım 19, 3 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 19, 3 resimden 2. Nikon D7000 Shutter Assembly Replacement: adım 19, 3 resimden 3.
    • Disconnect remaining ribbon cables.
    Note for D7100: at the top of the motherboard, there are 2 wide ZIF sockets (far left: white lever at top; far right: brown lever at bottom) and a narrow "no-fuss ribbon cable connector" (cable connector makes a 90° turn from 12 o' clock to 3 o'clock).
  20. Nikon D7000 Shutter Assembly Replacement: adım 20, 2 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 20, 2 resimden 2.
    One more ribbon behind press down tab
    Ziyang - Yanıt
    Note for D7100: at the bottom of the motherboard, there are 3 ZIF sockets (far left, top: black lever at bottom; far left, bottom (underneath the previous): black lever at top; adjacent to the right: black lever at top).
  21. Nikon D7000 Shutter Assembly Replacement: adım 21, 1 resimden 1.
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Shutter Assembly Replacement: adım 22, 1 resimden 1.
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Shutter Assembly Replacement: adım 23, 1 resimden 1.
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Shutter Assembly Replacement: adım 24, 1 resimden 1.
    • Lift the motherboard off.
  25. Nikon D7000 Shutter Assembly Replacement, Tripod Plate: adım 25, 1 resimden 1.
    • Remove four 6 mm J000 screws securing the tripod plate.
    Only left 2 screw need to be removed. The tripod plate do not need to be removed.
    Ziyang - Yanıt
    Actually, nothing needs to be removed !
    Skip this step and gain time and energy :)
    Xavier - Yanıt
  26. Nikon D7000 Shutter Assembly Replacement: adım 26, 1 resimden 1.
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
    Skip this step (see comment step 25)
    Xavier - Yanıt
  27. Nikon D7000 Shutter Assembly Replacement, Image Sensor: adım 27, 2 resimden 1. Nikon D7000 Shutter Assembly Replacement, Image Sensor: adım 27, 2 resimden 2.
    • Disconnect black and white speaker cable.
  28. Nikon D7000 Shutter Assembly Replacement: adım 28, 1 resimden 1.
    • Remove three 6 mm J000 screws securing the image sensor.
    Best to set markings on the three screws before removing sensor. To preserve alignment of sensor and body frame
    Ziyang - Yanıt
    This step is NOT necessary if you don't plan on doing anything with the sensor itself
    -> just let it all attached together and save yourself time and energy
    Xavier - Yanıt
    These 3 JIS #0 screws require quite some torque to unscrew.
    Don't forget to open the ZIF connector of the sensor ribbon cable before removing the sensor board.
  29. Nikon D7000 Shutter Assembly Replacement: adım 29, 1 resimden 1.
    • Carefully lift the image sensor plate out of the camera.
  30. Nikon D7000 Shutter Assembly Replacement, Shutter Assembly: adım 30, 1 resimden 1.
    • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
    • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
  31. Nikon D7000 Shutter Assembly Replacement: adım 31, 1 resimden 1.
    • Remove two 5 mm J000 screws from under the flash.
  32. Nikon D7000 Shutter Assembly Replacement: adım 32, 1 resimden 1.
    • Remove two 3 mm J000 screws securing the front cover.
    These screws should be the other way around. I took the 5mm screws out of the front cover. 3mm screws from under the flash.
    Jamie MacLeod - Yanıt
  33. Nikon D7000 Shutter Assembly Replacement: adım 33, 2 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 33, 2 resimden 2.
    • Remove the front cover.
  34. Nikon D7000 Shutter Assembly Replacement: adım 34, 1 resimden 1.
    • Carefully remove the port cover.
  35. Nikon D7000 Shutter Assembly Replacement: adım 35, 1 resimden 1.
    • Deroute the microphone cable.
  36. Nikon D7000 Shutter Assembly Replacement: adım 36, 1 resimden 1.
    • Remove one 4 mm J000 screw from the front.
  37. Nikon D7000 Shutter Assembly Replacement: adım 37, 1 resimden 1.
    • Remove one 8.5 mm J000 screw from the battery compartment.
  38. Nikon D7000 Shutter Assembly Replacement: adım 38, 1 resimden 1.
    • Remove the grip carefully.
  39. Nikon D7000 Shutter Assembly Replacement: adım 39, 1 resimden 1.
    • Remove one 4 mm J000 screw securing the top case (under right strap hook).
  40. Nikon D7000 Shutter Assembly Replacement: adım 40, 1 resimden 1.
    • Remove one 4 mm J000 screw securing the top case (under left strap hook).
  41. Nikon D7000 Shutter Assembly Replacement: adım 41, 1 resimden 1.
    • Remove the sticker covering the diopter adjust screw.
  42. Nikon D7000 Shutter Assembly Replacement: adım 42, 1 resimden 1.
    • Remove one 8.0 mm J000 screw.
    • Remove the Diopeter Adjust.
  43. Nikon D7000 Shutter Assembly Replacement: adım 43, 1 resimden 1.
    • Remove the top case.
    No mention of discharging the flash capacitor first?
    digimaan - Yanıt
    Make sure you don’t get a shock off it .
    Dean Wilkinson - Yanıt
  44. Nikon D7000 Shutter Assembly Replacement: adım 44, 1 resimden 1.
    • Remove the Black, Yellow, Green cable from the top case board.
    If intend to remove top panel entirely, will need to de-solder the black and red power cable
    Ziyang - Yanıt
  45. Nikon D7000 Shutter Assembly Replacement: adım 45, 3 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 45, 3 resimden 2. Nikon D7000 Shutter Assembly Replacement: adım 45, 3 resimden 3.
    • Remove two 6.5 mm J000 screws securing the viewfinder.
    • Remove the viewfinder cover.
    Not necessary to remove the viewfinder cover for mirror box
    Ziyang - Yanıt
  46. Nikon D7000 Shutter Assembly Replacement: adım 46, 1 resimden 1.
    • Remove one 3 mm J000 screw from the bottom left side of the camera.
    Don't do this : you don't need to, it's useless
    Xavier - Yanıt
  47. Nikon D7000 Shutter Assembly Replacement: adım 47, 1 resimden 1.
    • Remove two 6 mm J000 screws from the left of the shutter.
    Not necessary
    Xavier - Yanıt
  48. Nikon D7000 Shutter Assembly Replacement: adım 48, 1 resimden 1.
    • Remove two 6.5 mm J000 screws from beneath the lens mount.
  49. Nikon D7000 Shutter Assembly Replacement: adım 49, 1 resimden 1.
    • Remove two screws from just below and to the sides of the viewfinder.
  50. Nikon D7000 Shutter Assembly Replacement: adım 50, 1 resimden 1.
    • Remove one 5 mm J000 screw from the top right of the camera.
  51. Nikon D7000 Shutter Assembly Replacement: adım 51, 1 resimden 1.
    • Carefully peel back ribbon cable on the bottom left of camera.
  52. Nikon D7000 Shutter Assembly Replacement: adım 52, 2 resimden 1. Nikon D7000 Shutter Assembly Replacement: adım 52, 2 resimden 2.
    • Remove the left front ribbon cable from top right of circuit board.
    The illustration indicates this connector to be tilted upwards. I did - and broke the female connector. As shown on the right hand picture, the same thing has happened during the dismantling forming the basis for this “ifixit” instruction.
    This ribbon should be pulled straight out - not lifted upwards
    Bored Nomore - Yanıt
  53. Nikon D7000 Shutter Assembly Replacement: adım 53, 1 resimden 1.
    • Remove all three wire connectors.
  54. Nikon D7000 Shutter Assembly Replacement: adım 54, 1 resimden 1.
    • Separate the shutter assembly from the camera body.
    This part left me in the lurch a bit, undid the top 2 screws holding the shutter in but there seemed more to undo to actually release the shutter.
    digimaan - Yanıt
    If you intend to replace the shutter assembly only, you need to loosen it from the “shutter house” (don’ know correct term); (It is possible to purchase new blades only, but it seems complicated, and a shutter assembly costs around 35USD from Asia.)
    There are 3 screws; 2 visible on the “top” of the shutter assembly and one hidden underneath some ribbons on the “underside”. Study the new shutter to identify the screws being part of of the assembly and the ones holding it to the shutter house. (3 screws as mentioned)
    The power leads for the electric motor must be loosened by soldering (red and black cables).
    A ribbon with 4 tiny soldering points has to be loosened with a sharp tipped soldering iron; If you don’ t feel competent; bring it to someone who can do the very delicate soldering - especially for connecting the new shutter assembly.
    I have followed this guide. But 2 small bits of rubber have appeared. Not a clue from where. Any ideas?
    Paul Scott - Yanıt
    When opening the shutter assembly, there are 3 small rubber parts. A larger one at the bottom left, 2 smaller ones fit in the bottom right. You'll notice rectangular slots (horizontal or at 45°). That's where they fit.
    Olivier Biot -
Sonuç
35 farklı kişi bu kılavuzu tamamladı.
Steven Castaneda
691 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S24G6
3 Üyeler
5 adet Kılavuz yazıldı
10Kılavuz Yorumları
Use a #00 Philips, not a #0, or you'll strip the screws. Also, there are two or three screws connecting the shutter assembly to the camera body, and its contacts are soldered on. So you need a soldering iron for the last step.
Michael Duncan - Yanıt
im gonna be trying this soon , how long did it take and how difficult is it ,,,
Guide not completed. Last step only shows removal of mirror box. Shutter assembly replacement not
Ziyang - Yanıt
Regardless of possibly a few missing steps, this is a great lesson of how to deal with shutter replacement on my own. Hats off !!
Mateusz Witek - Yanıt
How to reassemble diopter adjustment?
Jerome - Yanıt
Can anyone help me with diopter control I took it apart by accident I don’t know how to put it back- jsarmd@yahoo.com
Jerome - Yanıt
what model cmos battery
Mohamad Farid Ghazali - Yanıt
Great that you posted link to Youtube video.
I had not been able to find the repair manual for this model and your step by step intructions helped me on the doubs I had.
Thanks.
Claudio Lupayante - Yanıt
Done mine but I do confess I got help from a mate how repairs mobile phones and computers make sure you note where all the screws go wee kept them in order when removing them so you no where thy all go when re assembling it back together I don’t think I would try to do it myself wee did take some photos helped when rebuilding it back together it worked ok after maybe wee were lucky
George aitchison - Yanıt
Where do I purchase internal parts for Nikon D series cameras? Thank you
Tony V - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 32
Son 30 gün: 111
Her zaman: 19,699
