Ana içeriğe geç
Nikon D7100 Headphone/Microphone Replacement
Neye ihtiyacın var
  1. Nikon D7100 Headphone/Microphone Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
  2. Nikon D7100 Headphone/Microphone Replacement: adım 2, 1 resimden 1.
    • Remove the 3 screws under the battery flap and remove the bottom cover.
  3. Nikon D7100 Headphone/Microphone Replacement: adım 3, 1 resimden 1.
    • Remove the 2 screws inside the camera on the back corners.
  4. Nikon D7100 Headphone/Microphone Replacement: adım 4, 1 resimden 1.
    • Open the HDMI flap and remove the 2 screws.
  5. Nikon D7100 Headphone/Microphone Replacement: adım 5, 1 resimden 1.
    • Remove the screw next to the camera strap loop.
  6. Nikon D7100 Headphone/Microphone Replacement: adım 6, 1 resimden 1.
    • Remove the 2 screws on each side of the view finder.
  7. Nikon D7100 Headphone/Microphone Replacement: adım 7, 1 resimden 1.
    • Remove the 2 screws above and below the SD card flap.
  8. Nikon D7100 Headphone/Microphone Replacement: adım 8, 1 resimden 1.
    • Peel off the adhesive leather screw cover and remove the 2 screws under it.
  9. Nikon D7100 Headphone/Microphone Replacement: adım 9, 2 resimden 1. Nikon D7100 Headphone/Microphone Replacement: adım 9, 2 resimden 2.
    • Remove the Diopter adjustment control sticker and remove the screw under it.
  10. Nikon D7100 Headphone/Microphone Replacement: adım 10, 1 resimden 1.
    • Separate the back panel of the camera from the actual camera.
    • Be careful not to tear any of the ribbon cables.
  11. Nikon D7100 Headphone/Microphone Replacement: adım 11, 1 resimden 1.
    • Disconnect the LCD ribbon cables and power cable from the motherboard.
  12. Nikon D7100 Headphone/Microphone Replacement: adım 12, 2 resimden 1. Nikon D7100 Headphone/Microphone Replacement: adım 12, 2 resimden 2.
    • Unscrew all 16 screws around the back plate of the camera.
  13. Nikon D7100 Headphone/Microphone Replacement: adım 13, 1 resimden 1.
    • Then unscrew the remaining screws holding the back plate to the LCD.
    • Then simply remove the plate with the LCD.
  14. Nikon D7100 Headphone/Microphone Replacement, Motherboard: adım 14, 1 resimden 1.
    • Undo the 5 ribbon cable connectors by flipping the latches up with a plastic spudger.
  15. Nikon D7100 Headphone/Microphone Replacement: adım 15, 1 resimden 1.
    • Remove the black 4 pin connector by pulling it out of the connector.
  16. Nikon D7100 Headphone/Microphone Replacement: adım 16, 1 resimden 1.
    • Remove the 7 screws holding the motherboard in place.
  17. Nikon D7100 Headphone/Microphone Replacement: adım 17, 1 resimden 1.
    • This is what you should see after removing the motherboard.
  18. Nikon D7100 Headphone/Microphone Replacement, Headphone and Microphone Module: adım 18, 1 resimden 1.
    • After following the guide to remove the back LCD screen from the motherboard, remove the 2 marked screws.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Wesley Eveld
731 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G6, Cheng Spring 2018 USF Tampa, Team S11-G6, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G6
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 14
Her zaman: 1,036
